Joestac
Timing worked out that my old Noco Boost was passed its prime and I needed something new and I have been so pleased with my Wolfbox Airduster that I thought I'd give the Wolfbox Jump Starter & Air Compressor a try. So far, very pleased with the device and it has earned a spot in the rear cargo area, despite already having a built air compressor in my Trailhunter
The device comes with a carrying case for the unit itself and all the needed accessories, along with a full user manual, and quick start guide printed on the back of the device just in case. Bonus, comes with the needed attachments so it can also air up my mountain bike tires if I'm out at a trailhead near the car and run into issues. I also used it to help some stranded road cyclists on the side of the highway that had a sealant blowout and had to throw in a tube but didn't have a great air pump.
I have not needed the battery booster yet and that isn't something I am just going to hook up and test on my hybrid, but I have faith it would work after seeing some independent reviews from places like ProjectFarm on YouTube. Charges via USB-C which is a nice upgrade from my Noco that was still micro-USB. It also has a built in light with 3 different settings in case you need to see what you are doing, or for a flashing safety light if you are stranded on the side of the road.
So far, it also seems to hold a charge quite well just sitting off in the back of the vehicle. I'll see how long I have to go in-between charges, but I am hopeful it will do better than the Noco that needed topping up every couple of months. I will see if I can test the tire inflator head-to-head with the built in compressor on my 4Runner and see how it compares but this also lets me help others on the trail while I can use my built-in to handle my tires to speed things along.
Edit: Wanted to update with some results airing up the tires on my Trailhunter.
For the test I put the tires at 15 PSI from their normal 38. Ambient temps are pretty warm but I had the vehicle shaded partly in the garage and partly in the driveway. So, somewhere around 90 degrees F. I also carry a Fanttik compressor so I wanted to test that against the others as well.
Something else I noticed that I don't know how much it matters but is a data point. The Wolfbox only lets you set the pressure as low as 26 PSI, the Fanttik lets you go to 3 PSI. I didn't test the TH, but I think that one lets you go pretty low as well.
Tires are 275/70/18 Toyo Open Country AT3 in E load.
Wolfbox: 15 PSI > 38 PSI : 07:17:90.
Fanttik X9 Ultra: 15 PSI > 38 PSI : 02:50:31
Trailhunter Built-In: 15 PSI > 38 PSI : 02:55:02
Trailhunter Built-In: 19 PSI > 38 PSI : 02:09:48
I let the TH air up the back two but one of them wasn't down to 15 so did two tests. Both the Wolfbox and the Fanttik got warm, the fans on the Fanttik kicked on. They both cooled down in about 10 minutes or so. Down side of the built-in on the TH is the vehicle needs to be running.
All in all, consider your use case here when deciding on one of these I guess. If you want something to use in case of emergency to jump start your car and air up a tire, the Wolfbox fits the need. If you want something specifically to air down and re-up your tires for off-roading, there are faster options out there that serve that one specific purpose.
For now the Wolfbox will definitely live in the wife's car in case she is ever stranded.
2025 2026 4runner 6th gen Wolfbox MV24A 4000A - Jump Starter & Air Compressor - Review 20260908_165604
2025 2026 4runner 6th gen Wolfbox MV24A 4000A - Jump Starter & Air Compressor - Review 20260908_165642
2025 2026 4runner 6th gen Wolfbox MV24A 4000A - Jump Starter & Air Compressor - Review 20260908_165545
2025 2026 4runner 6th gen Wolfbox MV24A 4000A - Jump Starter & Air Compressor - Review 20260908_165519
Product link:
I won mine through a contest here.
Great little device that had me postpone installing the THunter compressor on my TRD ORP. I've used it to air up from 18 to 35 PSI about 15 times.
Only issue is that it tends to overheat after two or so tires. With typical cool down time on a hot day, 4 tires takes about a half hour. On a cold day Less than 20 minutes. First tire typically takes about 4.5 minutes.
MikeK
Southern Nevada
Yeah, these little air compressors are only good for about 1 tire at a time. It's definitely not a good solution for airing up all 4 after airing down.
3rdRunner
Bill
Agree. The compressor in the TH is a great sales gimmick (worked on me…lol) but at 1.5-2 CFM it really is only good for topping off a tire or inflating floats. I had to learn that the hard way after deflating 4 35” tires down to 15 psi. I have a portable ARB Dual Compressor now and with a max output of 9.18 CFM (6.18 CFM @ 29 psi) it makes short work of getting back up to highway pressure with all 4 tires at once - about 5 minutes and 1 duty cycle. A little on the pricey side but it beats sitting on the side of the road for an hour or so just to get enough air back in to drive to someplace where you can finish the job…lol
Joestac
Joestac
Updated the OP with some tire results.
MikeK
Southern Nevada
I was referring to the 12v compressors. The TH compressor is an ARB compressor which is mounted to the inside the the rear quarter panel and it good for it's size. I have no problems using it to air back up the factory tires from 20psi to 33psi.
I don't think it's engineered for 35in tires, so that makes sense why it may struggle airing those up. Dual compressors are the way to go when airing up all 4 tires at the same time.
shine
Seattle
The TH compressor outputs at about the same rate as a standard valve can accept, so if you're airing up one tire at a time it's fine. If you're using a Morrflate system or similar, then a higher output compressor is useful.
Add the time it takes to deploy and put back your 4 tire hose system and the time difference isn't all that much. At least not if you're going - say - 18 psi back to 33 on a 33" tire.
I really like the fact that I can preset the pressure on the TH compressor, then move the hose from one tire to the next without having to do anything to the compressor.
3rdRunner
Bill
😂 Not even sure how to respond to that. Appreciate your insight!
