- Joined
- Nov 21, 2025
- Threads
- 27
- Messages
- 685
- Reaction score
- 518
- Location
- Austin, TX
- Vehicle(s)
- 2025 4Runner Trailhunter
- Thread starter
- #1
Timing worked out that my old Noco Boost was passed its prime and I needed something new and I have been so pleased with my Wolfbox Airduster that I thought I'd give the Wolfbox Jump Starter & Air Compressor a try. So far, very pleased with the device and it has earned a spot in the rear cargo area, despite already having a built air compressor in my Trailhunter
The device comes with a carrying case for the unit itself and all the needed accessories, along with a full user manual, and quick start guide printed on the back of the device just in case. Bonus, comes with the needed attachments so it can also air up my mountain bike tires if I'm out at a trailhead near the car and run into issues. I also used it to help some stranded road cyclists on the side of the highway that had a sealant blowout and had to throw in a tube but didn't have a great air pump.
I have not needed the battery booster yet and that isn't something I am just going to hook up and test on my hybrid, but I have faith it would work after seeing some independent reviews from places like ProjectFarm on YouTube. Charges via USB-C which is a nice upgrade from my Noco that was still micro-USB. It also has a built in light with 3 different settings in case you need to see what you are doing, or for a flashing safety light if you are stranded on the side of the road.
So far, it also seems to hold a charge quite well just sitting off in the back of the vehicle. I'll see how long I have to go in-between charges, but I am hopeful it will do better than the Noco that needed topping up every couple of months. I will see if I can test the tire inflator head-to-head with the built in compressor on my 4Runner and see how it compares but this also lets me help others on the trail while I can use my built-in to handle my tires to speed things along.
Edit: Wanted to update with some results airing up the tires on my Trailhunter.
For the test I put the tires at 15 PSI from their normal 38. Ambient temps are pretty warm but I had the vehicle shaded partly in the garage and partly in the driveway. So, somewhere around 90 degrees F. I also carry a Fanttik compressor so I wanted to test that against the others as well.
Something else I noticed that I don't know how much it matters but is a data point. The Wolfbox only lets you set the pressure as low as 26 PSI, the Fanttik lets you go to 3 PSI. I didn't test the TH, but I think that one lets you go pretty low as well.
Tires are 275/70/18 Toyo Open Country AT3 in E load.
Wolfbox: 15 PSI > 38 PSI : 07:17:90.
Fanttik X9 Ultra: 15 PSI > 38 PSI : 02:50:31
Trailhunter Built-In: 15 PSI > 38 PSI : 02:55:02
Trailhunter Built-In: 19 PSI > 38 PSI : 02:09:48
I let the TH air up the back two but one of them wasn't down to 15 so did two tests. Both the Wolfbox and the Fanttik got warm, the fans on the Fanttik kicked on. They both cooled down in about 10 minutes or so. Down side of the built-in on the TH is the vehicle needs to be running.
All in all, consider your use case here when deciding on one of these I guess. If you want something to use in case of emergency to jump start your car and air up a tire, the Wolfbox fits the need. If you want something specifically to air down and re-up your tires for off-roading, there are faster options out there that serve that one specific purpose.
For now the Wolfbox will definitely live in the wife's car in case she is ever stranded.
Product link:
Product link:
