- First Name
- Frank
- Joined
- Jul 21, 2025
- Threads
- 17
- Messages
- 185
- Reaction score
- 207
- Location
- San Clemente, CA
- Vehicle(s)
- 2025 4Runner TRD Off-Road
Not the best photo, but this was taken right after i did the install.Can you post some more pics of the trailhunter headlights on everest? I'm debating between the limited and the trailhunter lights
I have a question, what are the harnesses for? I have seen another thread where they didnt use those parts? I am just curious to see if I need them or not.Finally made the swap - took off the TRD Off-Road headlights and threw on a set of TRD Pro headlights.
I have always been obsessed with those amber DRLs on the TRD Pro and the Traihunter... and man, they look even better in person!
The install was 100% plug-and-play, zero issues. Also adding the sxth cold air intake, the turbo sound good!
Low beam:
High beam:
The passenger side:
The driver side:
Before upgrade the headlights:
I got the headlights for around $1,600
For anyone who was wondering, this is the coupon I used to get the discount of 25% off: GRob25Q324
Remember: The coupons only work when you are logged in. If you have already used it in the past, you will need to create a new account, just like I did!
And I ordered it through Toyota:
https://autoparts.toyota.com/
Good point! Part numbers and some pics here for the Limited/Platinum headlights: https://www.4runner6g.com/forum/threads/what-did-you-do-to-your-6th-gen-4runner-today-you prob want the limited/platinum headlights instead that only say "4RUNNER" on them
the trd pro has wording on them that say "TRD" passenger side and "PRO" on driver side head light assemblies
My understanding is that the PRO lights have amber DRL, and the limited as white, is that correct?you prob want the limited/platinum headlights instead that only say "4RUNNER" on them
If you are referring to the headlights it's all plug and play. No wiring needed.How difficult was the wiring harness setup? did you have to run through the firewall?
OK cool! I saw there were the wiring harnesses in the receipt so I thought maybe it needed a different setup going through into the dash.If you are referring to the headlights it's all plug and play. No wiring needed.
