YotaOverland
Mack
Yep, they will mount, but if you do the chalk test you’ll see that the sode of the tires likely donmt have much contact with the ground, if you call Falken they will likely advise removing this tire as quick as possible. I only speak about this because I went through the exact same thing on a previous vehicle, the tire store that I chose, discount tire, does not have accurate sizing for wheel width from the manufacturer.
Tennessee USA
F350
You are correct on Discount tire. They list 265's as the stock tire on a 2025 4R6g. I emailed them this morning as I was looking for alternate tires. I checked mine and the Toyota spec and they are 245. Bridgestone when I expected Yokohama for some reason.
jaymay82
Honolulu
'21 SR5 Super White, '25 SR5 Underground
I've heard the same about the 285's, which is why when i swap out the stock 245's, I'll be going with 265's.
I initially was going to wait and see if TRD wheels popped up for sale, but the dark grey/black SR5 wheels have really grown on me as they look better in-person. I'll be keeping mine.
bruce
Matthew
New Orleans
2025 4runner SR5
Are those SL or XL rated? I have an SR5 as well and the stock Geolanders are XL and the ride quality is too harsh.
nubbins_
time2playandy
Utah
Replaced the factory Geolander 245/70/17 with Falken Wildpeak 285/70/17 A/T4W.
No lift and no rub at all on the stock rim. I can feel the weight of the tire at first drive but seems fine after taking a few short drives. Tires seem as quiet as the factory ones that they replaced. So far very happy with the look and stance of the SR5. Also upgraded to the TRD center caps.
Will post an update in a few days.
How are you liking the tires after a few weeks? MPG? Any regrets? Thx!
richiecass
richiecass
Richie
New Jersey
I like them a lot. You can definitely tell the weight of the tires. The ride is very similar, except for the obvious Extreme pot holes where you can tell the difference.
The truck has a tight/stiffer ride than my tacoma does. But not that different since changing the tires. It's just the way the truck rides.
I'm down about a mile a gallon, but I'm going to calculate it again this morning and I'll repost to you.
k9Hiken
jesse
New Kent Va
2025 SR5
Run a 275/70/17 it will have a flatter side wall instead of the bloated one
FirstFourRunner6
St Louis, MO
Is something wrong with my 4Runner or what, haha? I've been running the same width tires (285/55R20) but am nowhere close to even 19 MPG driving as conservatively as possible. I even went with tires that have the lowest rolling resistance possible in that width - Michelin LTX AT2
