Rear tire carrier w/ rear camera?
4running
TX
2020 4Runner SR5
6thGen1419
Peter
New Mexico
Simple scenario; what if your spare tire is the wrong diameter from the rest of your tires and you are very far from anywhere you can get another one or repair the flat. Are you willing to risk damage to your differential and/or drivetrain?
Got it. You've answered my question. Thanks.
SR5CampLife
Eric
Elkton
2025 SR5 4Runner
Yea same. Posted this thread up last week - https://www.4runner6g.com/forum/thr...-carrier-released-carries-up-to-37-tire.8784/
Thinking about taking a chance on it. Haven't found any reviews yet though.
My only turn off is the distance from the rear tire from the hatch. I was hoping to find pictures of the swing down version to see if it's closer. I want something as close as possible without rubbing the bumper when it's folded down. I don't know, I have a vision in my mind of how the older land cruisers looked with them and I kind of want that on my 4Runner.
only thing i can find in the manual is if you the compact spare tire. max speed is 50 and may affect the 4wd system.
cant find anything for those that have the full spare negative points.
ChasingTrail
Taryn
Ozarks
I have mine on a swing out on the passenger side. The rear-view camera is now pretty much useless so I am looking at getting a Wolfbox and placing the rear camera on the spare tire as soon as I can figure out a license plate holder that can actually fit it. This is another huge surprise I had after I installed it since most of the universal plate holders are built using the deep offsets in mind. I think I may have to cut the bar that comes out of the middle of the wheel if they have enough holes to make them shorter.
Have you gotten a Wolfbox or found another solution for the camera yet? We're about to install a swing out tire carrier as well, looking for options.
Crose1695
seal beach
2026 4runner
@Wolfbox would work perfect for this. I don’t have a spare tire carrier but I do have the wolfbox tripro and I know for sure it would work just great. My rear camera for the wolfbox is mounted up underneath by the 3rd brake light. you would easily see over the tire and it’s adjustable
LostInAZ
Carlos
2026 Toyota 4Runner ORP
Yes, I am using a Wolfbox G900 TriPro attached to rear license plate on my spare tire (just a tad off-center but it works.
2025 2026 4runner 6th gen Rear tire carrier w/ rear camera? IMG_0963
benniayy
Calais
Boulder, CO
I don't get why people want their spare to match their in-use 4 upgraded tires, instead of just keeping the original full-size factory spare as a spare that's only used (if needed) long enough to get an in-use tire repaired or replaced. Same question for people who insist on doing 5 tire rotations instead of only rotating the 4 in-use tires. IOW, the spare is just that: a temporary-only spare.
Help me understand the reasoning.
For me it’s because I was stranded on a mountain pass because when I got a flat (I know this is my fault) ended up in a 6 hour ordeal with a rescue team. My rims didn’t fit the lug nuts to the donut lol and the dealer didn’t give me the extra standard lugs. I wouldn’t want to get off that pass with the donut anyway.
6thGen1419
Peter
New Mexico
My 4Runner factory spare is not a donut. It matches the four factory wheels/tires.
mfoga
Socal
r4unner
One of you has a SR5 and one of your has an ORP. Higher trims come with matching full siE spares while lower trims come with a emergency spare.
LostInAZ
Carlos
As long as the donut spare tire is the same diameter as the rest then there is NO issue. But if you install 35" tires I don't think there is any donuts that will have the same diameter and you won't be able to install one underneath the back. Why risk the damage?
