- Thread starter
- #1
Anyone order the rear diff skid plate? Specifically PT228-89254
Just opened the box and I am missing 2 rubber parts(circled in green). This is for the NON-Hybrid.
Edit: Found out that it is not needed. Also for the front/center skid plates, go to the bottom.
ATTACHED PDF SHOWS THE FOLLOWING:
PT228-89254 -ALL Gas Models and LIMITED/Platinum HV Models
POST INSTAL EDIT, THEY ARE NOT NEEDED FOR THE NON HYBRIDS:
1- Be VERY careful on the brake lines! I recommend you tape up the brake lines where the brackets slide under. The will likely scratch it up. See the attached instructions. I unscrewed all the brake line tie down locations. It makes it easier to move it out of the way.
2- The small black brackets are angled, you can install them on backwards! There is only one way they go on. Again see the instructions. In addition, the big skid plate can ALSO be installed on backwards! Some in this forum did, please see the PDF and note the orientation to the front of the vehicle!
See attached PDF installation guideline, torque to spec.
Also installed:
Front Trd Aluminum skid: PTR60-35240
Transfercase STEEL skid: PT228-35248
Rear Diff STEEL skid: PT228-89254
This skid is shown for the 4runner and Land Cruiser as a direct fit. PT228-35242 is the Tacoma plate and comes with the rubber stops I've shown above.
Also installed:
