Oil Change Tips w/ Skid Plates?
djk
Dan
Bay Area
4Runner ORP
I have the RCI skid plates that has access to the drain plug and filter and it doesn't look like it should be too difficult to get to.
The question I have is, anyone have tips to prevent/clean up messes? Esp. where the oil comes out of the drain plug?
When the dealership did theirs, it looks like it made a mess that they just wiped down. My less than ideal plan is to just have a lot of shop rags handy
2025 2026 4runner 6th gen Oil Change Tips w/ Skid Plates? Screenshot 2026-07-28 at 4.22.17 PM
Bindul
2025 Toyota 4runner sr5 4wd 3
I'd suggest you slide a piece of thick cardboard or a plastic tray directly over the top of the skid plate, angle your catch pan slightly back because the oil shoots out sideways at first, and consider swapping to a specialized drain valve later.
  • Like
Reactions: djk
Kurvet
Aim the pan back: Position your drain pan slightly offset toward the rear/side, as the initial stream shoots out at an angle rather than dropping straight down.
  • Like
Reactions: djk
6thGen1419
Peter
New Mexico
I remove the skid plates when doing oil changes. It ends up being the easiest.
djk
djk
Dan
Bay Area
4Runner ORP
Picked up one of these from amazon, it's amazing thanks for the rec!
HVLA
Lexus
Also helps to leave oil cap on to slow the draining down.
  • Like
Reactions: djk
