PdlMnk
6G4R - TRD ORP Premium Hybrid
I did watch it like 50 times, somehow I always missed him saying "cut". Thanks for leading me back on the path :)
That being said, I have no power coming out of the connector to the compressor module. The module fuse is good, the 50amp looks good. I know my multimeter works as I tested it in the 120VAC outlet and tested on my 12V battery, which read 13.99V.
Any ideas what might be going on here? Also, this 50amp fuse is not a fuse I'm used to seeing. How do I get it out?
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 20260905_154403
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 20260905_154839
PdlMnk
I'm wondering if anybody has this working on a 2026? I have a 2026, but I think most others are 2025?
pmedicj
MA
Hmmm. I hooked mine up on my Pro and didn’t have to do the step with the wire. I don’t think the wire is cut I think the ground is spliced into the brown wire.
Also, I do know that no power goes to the unit unless the vehicle is turned on and running. Maybe that’s the problem.
PdlMnk
Thanks, yeah, had the 4runner running. For the TRD ORP Hybrid you have to cut the wire and wire it to ground so that it thinks it's seeing the parking brake on all the time. This is a known limitation for our models.
PdlMnk
Holy shit! I think I found the problem. There is aan entire connector missing from one side of the 50amp fuse. The fuse is intact and working (I tested continuity). Check out this pic from the fuse box.
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 20260906_114050[1]
PdlMnk
Just in case there is any doubt this is the fuse, here are more pics.
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 1788720882184-vj
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 20260906_115159[1]
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 20260906_115242[1]
PdlMnk
Probably a tall order, but if anyone is willing to check to see if they have the blade on both side of the 50amp fuse, I would be grateful. Better yet, you installed the air compressor and it works and you check to see if the blade is there.
As an FYI, pulling the fuse is a slight pain. If you don't havve the right tool, I used 2 hooks to pull each side under the blude ridge in the middle of the 3 fuses. Here's a pic of where the ridge is on both sides of the fuse.
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY Screenshot 2026-09-06 120602
pmedicj
MA
It looks like you found the problem. I think your going to have to find a way to wire it to power with your own fuse like they did with the SR5
PdlMnk
Thanks for that video, it helped a lot.
I am still stuck on one thing, I need to run the ignition wire so that the module knows the power is on. What do I tapo into back there? The battery is in the rear, so it should be an easy run. Below is the diagram I made. If someone could please take a look aadn let me know if you see any flaws in my plan?
2025 2026 4runner 6th gen OEM Onboard Air Compressor (Tire Inflator) install complete using how-to DIY 1788811907929-3f
mcj_orp
2026 TRD Off Road Premium iForce MAX
Wouldn't that be a warranty issue? It SHOULD be there, right?
PdlMnk
No, because the OEM Air Compressor is not an option for the TRD ORP Hybrid.
mcj_orp
Right but as far as I can tell by other people installing it, it should be there, no? It seems defective as it's missing a blade. And the connection is there.
PdlMnk
I haven't seen anyone confirm it worked for them on a 2026, so it's possible they remove it for 2026?? Who knows *shrugs*. Too late anyway, I cut the connector off and redid it myself.
mcj_orp
Yea, I saw that. Nice work by the way. Ed Martin Toyota posted a youtube video using the rear connection on a Hybrid ORP.
PdlMnk
yeah, this is the video that inspired me to do it! Too bad it didn't work out this way for me. And thanks!
