Its a Digital Sound Processor which processes the sound. You can adjust the certain bands to your liking. The beatsonic alpha is just a line level booster which you can only adjust gains and in a jbl system you can only adjust total gains cause the jbl system only uses the front output to the jbl amp.How can they call it a DSP but you are only able to manipulate gain?
I can already do that with the EQ. There is no way to do that with the BeatSonicIts a Digital Sound Processor which processes the sound. You can adjust the certain bands to your liking. The beatsonic alpha is just a line level booster which you can only adjust gains and in a jbl system you can only adjust total gains cause the jbl system only uses the front output to the jbl amp.
Were there any certain door rattles you went after? I have one that sounds like it’s from the drivers exterior handle but echoes up through the back pillar of the drivers door. I’ve done some dynomat but no luck shutting it down so far.
Awesome. Thank you! I will be opening it back up this week. It has been driving me absolutely crazy.Its funny that you had mentioned that as i have had some noise coming from the doors. One is inside the drivers side view mirror. That will have to be replaced as I dont want to open that up.
The other is the windows run channel brackets in both front doors. I tried to post a video of the noise but I guess the file is too big. But how the chanel bracket was designed, it cradles the run chanel thats part of the door frame. There is excessive clearance and nothing to dampen it as its metal to metal. I have put closed cell foam pieces on the bracket to insulate the two metals from making noise. I did not use anything like felt or other foam as it will be exposed to water and did not want that to create rust.![]()
Sorry no pic of the foam placement but if you look at it you'll know where to put them. Kind of on the inside of the outer piece shown in pics. If you look closely at the dimples where it contacts the door frame window run it has marks which go to metal. A little touch up paint will do to prevent from rusting.
Someone else posted pictures too.Awesome. Thank you! I will be opening it back up this week. It has been driving me absolutely crazy.
