Maximus4R
Adam
Nashville
Were there any certain door rattles you went after? I have one that sounds like it’s from the drivers exterior handle but echoes up through the back pillar of the drivers door. I’ve done some dynomat but no luck shutting it down so far.
ToyoTech808
ToyoTech808
Honolulu
25 4runner
How can they call it a DSP but you are only able to manipulate gain?
Its a Digital Sound Processor which processes the sound. You can adjust the certain bands to your liking. The beatsonic alpha is just a line level booster which you can only adjust gains and in a jbl system you can only adjust total gains cause the jbl system only uses the front output to the jbl amp.
Vincenzo
Southeast
I can already do that with the EQ. There is no way to do that with the BeatSonic
ToyoTech808
ToyoTech808
Honolulu
25 4runner
The audio unit eq is only Lo Mid Hi settings. You can not adjust individual frequencies like the DSP beatsonic Encore X. You would need a laptop and other equipment to tune the sysytem.
The Beatsonic alpha is only a line level booster and there is no eq adjustments.
This is the Alpha line level booster
https://www.beatsonicusa.com/products/ena-2t3?variant=44580022911127
This is the line level booster with DSP.
https://www.beatsonicusa.com/products/enx-t330
