6GenChad
6GenChad
Tommy
San Diego
For me after installation, the map lights no longer light up when i walk up to the car. only the dome light. Do you have a similar issue?
Haven’t noticed anything, mainly because my switch is turned to off, I’ll only turn them on at night when driving
6GenChad
6GenChad
Tommy
San Diego
if they were anything like the 5th gen map lights, use a plastic pry tool.
i have seen way to many people short out a BCM module on the 5th gen prying with a metal screwdriver and short circuit the bulb housing to the reflector.
i was lucky, i used duct tape to pull out the bulbs and even then i shattered 1 oem bulb pulling them out.
you could pull off the plastic clear len's (that you pushed to turn on/off) and just replace the bulb instead of the whole housing.
I didn’t remove any bulbs doing this, I believe they’re inside the actual housing itself. One harness powers the entire unit, once you unplug that it’s disconnected. After you pop the bezel off and a couple other pieces, make holes, put the lights in, bezel back on, and you pop it in again, you’re done.
RunnerRocks
Wanderer
Wandering
2026 TRD ORP
not sure, i usually wait a year or two before the mainstream companies post bulb numbers.
usually like vleds, lasfit, retrofit source, diode dynamics, etc posts them after a while.
I contacted VLEDS. Below is their reply.
2025 4runner 6th gen MESO Customs Dome Lights Install DIY - How-to & Photos 20260107_160112
lol, yeah i know that the map lights can be repalced.
i mean lasfit has replacements out for them.
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Their website says that you lose the functionality of the dome light turning on as you walk up to the car if you installed these.
Noticed this in the Owner's Manual.
on the 5th gen (before they went led) you could pull the len's out and replace the bulb directly, hence the reason i said that. i havent looked into the 6th gen, as its winter time and i really dont do any mods until spring/summer in ND.
and thats usually after april at the earilest. just to wet/slushy/cold before then and i dont have a heated garage to do mods.
so i am limited.
i had to put off the vinyl insert mod on the back "toyota" and screen protector since it got too cold in october and wont warm up enough until after april.
6GenChad
6GenChad
Tommy
San Diego
Well, when I open the door, they come on. I think it’s because they have a slight delay in turning on. I always turn my car on first, and they light up when I get in
T_Pomp
Anthony
Illinois
Understood, but someone in this thread asked the question if the dome lights still activate when approaching the vehicle which they do not when these are installed.
6GenChad
6GenChad
Tommy
San Diego
Interesting, I’ll check it out tonight and report back
6GenChad
6GenChad
Tommy
San Diego
Oh well, doesn’t really bother me personally, my windows are so dark I can’t even see inside of them at night, so I could barely see the light anyways haha
VB4Runner
Mitesh
2025 TRD ORP
Curiously enough, this doesn’t hold true for me. I’ve got the dome and map lights installed, and I just walked up to my truck with keys in my pocket and the dome light illuminated as I approached the driver door.
6GenChad
6GenChad
Tommy
San Diego
I just did it right now and same thing happened
jaymay82
Honolulu
'21 SR5 Super White, '25 SR5 Underground
Had a chance to install mine this past weekend. The difference is literally night and day. It's a darn shame that the amount of money we pay for these 4Runners that the OEM lights are such a joke being so dark.
Couple things noted:
-Removal of the overhead console is easy if you use the pry tool and approach it from the front of the vehicle. The 2 push-in style clips are at the front of the console. Do not try to remove the console from the rear-side as there are plastic hinge clips that are not meant for removal.
-Removing the 10 bezel clips were kind of a pain at first. I recommend using a flat head screwdriver as mentioned in the video, but also at the same time, sticking a pry tool under the bezel while pushing the clips with the flat head screwdriver.
-Didn't disconnect the battery and had no issues. I did make sure to have the light switch on the overhead console in the "off" position when reconnecting the wires.
While is is a pretty pricey upgrade, it is totally worth it. Especially if you have to access your vehicle in the dark every day like me (early work commuter).
