Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
Sort of, yeah.
10m-30m here and there so 30-60ft distance/spread.
Some difference is noted, given the Acceptable rating vs Poor.
Is that worth the $2,000 investment though....
Certainly not everyone's need but I got mine for $1420 plus tax during the 25% off sale so for me it was worth it
So much better than the stock ones. I love them!
stephbm6
Salt Lake City, Utah
So are they just plug and play? Do you need any extra wiring for the high/low beam since you said they are separate wires.
J4runner721
J4runner721
Jay
Washington
2025 Toyota 4runner Off-Road, 09 Legacy Spec.B, 2019 Subaru Crosstrek
Yes, its plug and play, no additional wiring required. I updated the post so people don't get confuse on their install. Also, I added a link reference on how to remove the front bumper.
Yoosuhhh
Shane
florida
2025 4Runner TRD Offroad premium iForceMax, 2018 4Runner TRD Offroad
Installed Limited Headlights w/ 4Runner Badge (Etsy 😅) on the Hood
For anyone interested in doing this upgrade, it’s fairly simple. I highly recommend disconnecting the battery anytime you’re working with electrical components such as headlights or fog lights.
Part Number: 81070-35661 - Unit Assembly, Headlamp, B Left Hand
Part Number: 81140-35661 - Unit Assembly, Headlamp, B Right Hand
When removing the headlights, make sure to disconnect the two harnesses located on right passenger side of the headlight. (Be sure to connect them properly once you're finish, otherwise you'll unlock a can of worms; check engine lights, codes, etc. etc.)
Please refer to video: How to remove front bumper
The entire process takes roughly 1.5 hours from start to finish.
It is purely Plug and Play, no additional harness required for the installation.
Limited(Premium) headlights have three connectors total:
  • One connector for the DRL/turn signal
  • Two connectors for the low beam and high beam
  • One extra connector that is not used (I pointed this out with an arrow in the photo of the back of the headlight)
The headlights can be adjusted by using the headlight leveling control knob on the driver’s side.
Overall, a straightforward install and a great OEM+ style upgrade.
Yoosuhhh
Shane
florida
Does this swap let you have the amber DRL or it stay white?
Maximus4R
Adam
Nashville
I think it depends on which trim you source the lights from. I believe pro and trail hunter have amber DRL while the limited gets white.
Yoosuhhh
Shane
florida
That makes sense, does anyone know the part number for the TRD Pro headlights?
