Does a quick release awning exist for the OEM roof rack?
PdlMnk
6G4R - TRD ORP Premium Hybrid
I don't think it exists. I've checked many sites. Anybody have a quick release with the OEM roof rack and cross bars? Thanks!
mfoga
Socal
r4unner
I have never seen anything but Yakima basic ones are easy to factory type bars. Unlock it loosen the bracket. Is not just couple pins but maybe 5 min max.
828findadventure
North Carolina
Tacoma & Tundra
I am sure something could be fabricated to hold a bracket. BUT, the ends of the OE cross bars are plastic, and the rails are extruded aluminum. You could drill some holes and bolt them on but a better solution would be new cross bars like the ones from Victory 4x4.
2025 2026 4runner 6th gen Does a quick release awning exist for the OEM roof rack? IMG_4133
ThatSickRIp
TSR
2026 4Runner SR5
@828findadventure How high do the Victory crossbars sit over the side rails? Or better yet, how high are they compared to the shark fin antenna?
ToYoDaMan
Allan
Bay Area
I like how these crossbars mount and clamps right on the oem rails with the provided adhesive rubber grip linings. Thinking about going this route and create a full platform with 4-5 of these Victory crossbars.. their install instructions on all their products are top notch.
I can keep my oem rails and will just have to remove the oem crossbars that had to come with the Runner when purchased. I can remove them anytime and not fully commit to a permanent rack upgrade. Cost savings is also significant. Good enough for my needs.
ThatSickRIp
TSR
2026 4Runner SR5
Im thinking the same thing as well.
Im just limited by height in my garage, so I need to see how high these sit. If low enough, Im probably going to get them
PdlMnk
Yes, you can certainly fabricate parts and I've looked into it. I posted something about that, but no replies. Ultimately, I think I will put on the new slim sport 3 from Frontrunner and then no fab necessary.
https://www.4runner6g.com/forum/thr...que-my-design-before-i-buy.12040/#post-161034
828findadventure
North Carolina
Tacoma & Tundra
The crossbars sit just above or level with the shark fin. They clamp to the roof rails and can be positioned anywhere in that section, unlike the OE cross bars.
828findadventure
North Carolina
Tacoma & Tundra
Video:
ThatSickRIp
TSR
2026 4Runner SR5
Awesome! Ive got 1.5" of garage clearance from the shark fin, so I was already very limited on racks outside of a few. And Id hate to have $1k+ in a rack plus install, just to find out I cant fit in the garage with it on.
Have you added any more crossbars yet? It looks like 4 might be tight up there, but I think Id rather have more of a platform to work with that way vs too much space in between
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Are the OE rails flat so that 3 or more crossbars will provide a flat surface ?
ThatSickRIp
TSR
2026 4Runner SR5
Without putting a level on mine, I would say yes based on what I see on LFDs website with a similar product
2025 2026 4runner 6th gen Does a quick release awning exist for the OEM roof rack? 20260107_150415
ToYoDaMan
Allan
Bay Area
This was my other option . I didn't like the fact that iit does not have the rubber grip protective lining within the clamps that attaches to the rails.
Also by the looks of it, the crossbars seems to sit higher on the roof than the Victory crossbars or maybe the Victory crossbars just have flatter profile and not necessarily a lower vertical depth with respect to the roof height.
828findadventure
North Carolina
Tacoma & Tundra
Just to throw in some measurements. The shark fin sticks up a half inch above the side roof rails. The victory 4x4 cross bars stick up about an inch. I think pulling into your garage will be close, but I think it will clear.
828findadventure
North Carolina
Tacoma & Tundra
No, the OE are slightly arched and are thick.
2025 2026 4runner 6th gen Does a quick release awning exist for the OEM roof rack? IMG_4104 copy
