mcd_ovrlnd
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Thanks for post. Do you have pictures of how they ran your cable to the back to the battery. Just trying to see if an installation process.
I’ll follow up with some info on this.
n1comedes
San Diego
Toyota 4Runner
I recently purchased the Dswitch panel and C2 2.0 chase lights to work with my Baja Designs rock lights on my roof rack. I want to be able to control the left pair and right pair rock lights and pair of chase lights separately as well have all of them turn on when i unlock the car on the keyfob and when i open the door to exit. Is there a way to be able to accomplish all that? Looking for guidance. Thank you in advance
mcd_ovrlnd
mcd_ovrlnd
SE PA
You can most definitely hook up each pair to a different slot on the switch so that each pair operates off its own button. You can even use a fourth button on the controller and assign all three other buttons to it so you could turn everything on with just one button. The switch does come with ignition wiring so you can tie things to the car starting up but not sure if that means you could tie it to the unlock or opening the door. I guess if you could find the right wires that control those things you could tap into them. I wasn’t interested in that so didn’t educate myself enough in those features. I saw Diode posted on another thread about the switch now being on CarPlay. Hop on that thread and ask diode directly.
