DeStreGa5
Andrew
My sub lapsed a while ago but yes I had all of those options on my 26 SR5 and disabled all of the seat belt dings
I asked if this might change in the future and their response is below.
I wonder what has changed in the time that morsk turned off his dings and now. I know he could probably just plug in the OBD tool and look through the app without the subscription. That's what I've been doing about once a week just to see if I should pay for the subscription. Maybe he could chime in and see if it looks like same as ours or not.
morsk
NY
2026 SR5
Honestly, after reading some of the responses ITT and the useless response from Carista that someone posted, I'm scared to plug my Carista into my vehicle if it were to somehow reset my settings (I know it probably won't without some kind of firmware update on the OBD tool, but still). Not gonna do that, I'm enjoying my dingless seat belt reminder :)
i guess we have to see what the creader options will produce. i am guessing they go deeper than the carista option but man that gets spendy for a $180 option just to turn off some seat buzzer's.
morsk
NY
2026 SR5
And just a general note: I activated my Carista subscription on 7/14/26 to change these settings on my 2026 SR5. So this was available for customization until at least then
for 2025 MY the options for seat buzzer are still available (i verified this on my 25). its just the 2026 MY there is no longer the option to change the seat buzzer for the 4 seat positions.
so i am guessing carista hasnt gone in an looked at what has changed on the seat buzzer setting in MY 26 4runners. its probably in a different pid than 2025 MY.
its still probably accessible via GTS (global techstream) just not carista.
waiting for feedback on the person that was buying the creader elite v3 for toyota/lexus to see if they can see the seat buzzer setting and able to change it.
ThatSickRIp
TSR
2026 4Runner SR5
Sample size of one, but I used Carista last weekend on my 26 SR5 and had all my options available. Obviously not as many options as your higher trim, but everything Ive seen on this site for it were available.
does it show 2 options for dings & warnings or 9 options ???
if it two then you are missing 7 options which includes turning off the seat buzzers
ThatSickRIp
TSR
2026 4Runner SR5
Id have to check again, but I recall having several for the front and several for the rear, so more than I initially thought it would have.
DeStreGa5
Andrew
I have never seen seatbelt dings available on my '26. I'll check again when I get home.
if you go into carista you should only see 2 options on a 26 and none are for the seat belt dings
on my 2025 4R platinum have this, 9 options
2025 2026 4runner 6th gen Carista Options / Settings for 2025+ 4Runner 6th Gen (screenshots) 1791227592393-ds
I just have these two for that menu.
so it seems its just not isolated to my 26 platinum where there is only 2 options vs my 25 platinum having all 9 options.
so toyota did something to where carista can no longer change those options on the 26+ 4runner.
my back of the napkin guess is the pid changed for the seat buzzers.
there are more options that where either added or removed not just under that section from what i have noticed.
so i did an export and did a side by side comparison of the options you can change in carista, guess what is the only thing missing on my 26 platinum vs my 25 platinum, yep the 5 seat buzzers
options on both vehicles are about the same, some are slightly more safety oriented for the wife's 26 since she likes to keep her fob in a purse vs me having mine on a carbiner.
2025 4runner platinum carista export2026 4runner platinum carista export
Chassis & Engine:
Active Noise Cancellation (ANC)Active Noise Cancellation (ANC)
ON / *OFF*ON / *OFF*
Engine Sound Enhancement (ESE)Engine Sound Enhancement (ESE)
Dings & Warnings:
Warn when doors opened with headlights onWarn when doors opened with headlights on
*ON* / OFF*ON* / OFF
Seat belt warning ding (driver)MISSING
ENABLED / *DISABLED*
Seat belt warning ding (front passenger)MISSING
Seat belt warning ding (rear right passenger)MISSING
Seat belt warning ding (rear left passenger)MISSING
Seat belt warning ding (rear center passenger)MISSING
Ding when key is left in the carDing when key is left in the car
*ENABLED* / DISABLED*ENABLED* / DISABLED
Driver Assist:
Rear Cross Traffic Alert (RCTA) systemRear Cross Traffic Alert (RCTA) system
Blind spot monitorBlind spot monitor
Heater & A/C:
Temperature dial calibrationTemperature dial calibration
-2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F)-2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Instruments: Displays & Nav:
Instrument lights restoring sensitivityInstrument lights restoring sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTESTDARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…Display odometer after ignition is turned off for…
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Microphone sensitivityMicrophone sensitivity
44
Speaker volumeSpeaker volume
Instruments: Heads-Up Display (HUD):
Image distortion in heads-up display (HUD)Image distortion in heads-up display (HUD)
CONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / *DEFAULT* / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGHCONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / *DEFAULT* / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGH
Lights: Automatic:
Auto headlights activation thresholdAuto headlights activation threshold
Turn headlights on when wipers operated continuously and headlights are switched on AUTO (req. auto headlights)Turn headlights on when wipers operated continuously and headlights are switched on AUTO (req. auto headlights)
Lights: Exterior:
Daytime running lightsDaytime running lights
Lane-change turn signal auto-flasher countLane-change turn signal auto-flasher count
OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / *7 FLASHES*OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / *7 FLASHES*
Turn signal click volumeTurn signal click volume
LOW / MEDIUM / *HIGH*LOW / MEDIUM / *HIGH*
Coming-home lights durationComing-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDSOFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Turn on marker lights when vehicle is unlocked via remoteTurn on marker lights when vehicle is unlocked via remote
Lights: Interior:
Turn on interior lights when you shut off engineTurn on interior lights when you shut off engine
*YES* / NO*YES* / NO
Turn on interior lights when smart key in rangeTurn on interior lights when smart key in range
Interior footlight (bright when doors open, dim when driving)Interior footlight (bright when doors open, dim when driving)
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
Locking: Automatic:
Re-lock doors automatically if you unlock, but don't open a door within…Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS30 SECONDS / *60 SECONDS* / 120 SECONDS
Locking: Beep & Blink:
Blink hazard lights when vehicle is locked via remoteBlink hazard lights when vehicle is locked via remote
Locking: Doors & Alarm:
Max number of consecutive lock/unlock cycles via touch sensorMax number of consecutive lock/unlock cycles via touch sensor
*UNLIMITED* / 2 TIMES*UNLIMITED* / 2 TIMES
Warn (beep) when a window is still open when locking doorsWarn (beep) when a window is still open when locking doors
Warning when door is locked via button on door handle while ignition is left onWarning when door is locked via button on door handle while ignition is left on
Locking: Smart Key:
Touch-to-unlock-doors minimum durationTouch-to-unlock-doors minimum duration
*OFF* / SHORT / MEDIUM / LONG*OFF* / SHORT / MEDIUM / LONG
After locking with smart key, don't allow re-opening within…After locking with smart key, don't allow re-opening within…
*0.5 SECONDS* / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS*0.5 SECONDS* / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start carSmart key location to start car
*FRONT AND BACK SEATS* / ANYWHERE IN VEHICLE*FRONT AND BACK SEATS* / ANYWHERE IN VEHICLE
Mirrors:
Auto fold side-view mirrors (req. power folding mirrors)Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / WITH DOOR LOCKS / *DISABLED*WITH IGNITION / WITH DOOR LOCKS / *DISABLED*
Parking Sensors:
Activate parking sensors in neutral (N)Activate parking sensors in neutral (N)
Front center parking sensor rangeFront center parking sensor range
SHORT / *LONG*SHORT / *LONG*
Front corner parking sensor rangeFront corner parking sensor range
Parking Support Brake (PKSB) vehicles from rear detectionParking Support Brake (PKSB) vehicles from rear detection
Parking Support Brake (PKSB) rear detection sensitivityParking Support Brake (PKSB) rear detection sensitivity
*STANDARD* / LOW*STANDARD* / LOW
Seats & Steering Wheel:
Seat airflow levelSeat airflow level
NORMAL / *SILENT (HIGH)* / SILENT (LOW)NORMAL / *SILENT (HIGH)* / SILENT (LOW)
Easy entry/exitEasy entry/exit
*DISABLED* / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXITDISABLED / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / *TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT* / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk:
Rear hatch walk away kick sensorRear hatch walk away kick sensor
ENABLED / *DISABLED*ENABLED / *DISABLED*
Trunk kick sensor sensitivityTrunk kick sensor sensitivity
*LOW* / MEDIUM / HIGH*LOW* / MEDIUM / HIGH
Trunk front seat switch buttonTrunk front seat switch button
SHORT PRESS / *LONG PRESS*SHORT PRESS / *LONG PRESS*
Rear hatch open/close via remoteRear hatch open/close via remote
*ON* / OFFON / *OFF*
Rear hatch open/close with "one motion"Rear hatch open/close with "one motion"
Rear hatch remote pressRear hatch remote press
SHORT PRESS / 2 SHORT PRESSES / *LONG PRESS*SHORT PRESS / 2 SHORT PRESSES / *LONG PRESS*
Beep while opening/closing power rear hatchBeep while opening/closing power rear hatch
Windows & Sunroof:
Open windows and sunroof via long-press on remoteOpen windows and sunroof via long-press on remote
Sunroof action when opening via holding down the driver side key for 1.5 secondsSunroof action when opening via holding down the driver side key for 1.5 seconds
*SLIDE* / TILTSLIDE / *TILT*
Sunroof action when opening via remoteSunroof action when opening via remote
*SLIDE* / TILT*SLIDE* / TILT
Beep when using windows comfort close with ignition offBeep when using windows comfort close with ignition off
Open windows and sunroof by turning and holding key in door lockOpen windows and sunroof by turning and holding key in door lock
Close windows and sunroof by turning and holding key in door lockClose windows and sunroof by turning and holding key in door lock
Passenger window single-touch-open from driver's switchPassenger window single-touch-open from driver's switch
Window (rear left) single-touch-open from driver's switchWindow (rear left) single-touch-open from driver's switch
Window (rear left) single-touch-close from driver's switchWindow (rear left) single-touch-close from driver's switch
Window (rear right) single-touch-open from driver's switchWindow (rear right) single-touch-open from driver's switch
Window (rear right) single-touch-close from driver's switchWindow (rear right) single-touch-close from driver's switch
Wiper voice controlWiper voice control
Wipers & Washer:
Auto-enable rear wiper when front wipers on and reverse gear engagedAuto-enable rear wiper when front wipers on and reverse gear engaged
SWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / *TURN ON ONCE* / DISABLEDSWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / *TURN ON ONCE* / DISABLED
Enable rear window wiper when trunk is openEnable rear window wiper when trunk is open
Other:
Panic function on remotePanic function on remote
I got 2026 4Runner Sport Premium and got all options like it's supposed to 🤷
