J4Runner1
James
Yes E load. No big change. It's still shit MPG lol apparently it takes a while for the car to show its true efficiency. Have you heard this?
That's good to hear. I have seen that on a lot of forums and videos about the break in. Right now I’m getting about 20mpg with mixed driving. Less than 300 miles though and only one tank of gas.
The only issues are these KMCs. They don't balance well and have vibrations. Ill be swapping back to a Method Wheel soon.
What a PIA. Hopefully the change to Methods will fix that. I’m looking at Black Rhinos or Methods.
Last thing I'll leave you with is these K03s look skinny at 295 lol I wish they were wider. But by design they kind of taper into the tread pattern which is narrower than the full
Thats good to know. Probably going to go with 285/75r17 on Methods or Black Rhinos.
Thanks for the info.
JMOprime
2025 Toyota 4Runner SR5
Went with 265/70R17 on stock SR5 wheels and swapped out the center caps with ones with the TRD logo.
Loving the raised white lettering on the tires. Gives a race-y F1 feel to them. Definitely have seen a 1-2 mpg drop since installation but worth the trade off!
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7148
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7150
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7151
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7155
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7154
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Here's a 2025 4Runner TRD Off-Road on:
Toytec Spacer Lift Kit (2.5" lift)
Method Wheels (703) +35 offset
General Grabber A/TX (35x12.5x17)
Some pics and a video:
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 2025 4Runner TRD Off-Road Toytec Spacer Lift Kit (2.5%22), Method Wheels (703) +35 offset, G
JenningsESQ
Jon
Underground SR5 on
✅ Nitto Ridge Grapplers 35x11.50R17
✅ Method 318 Wheels 17x8 +25 offset
✅ Old Man Emu MT64 3" inch suspension kit
✅ ARB Roof Rack
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! -kit-nitto-ridge-grapplers-35x11-50r17-met-jpg-
lb1606
FL
I understand Method wheels have a hub bore size of 106.25 while 6th gen 4runners is a bit smaller at 95.1mm. Did you use a hub centric ring or extended thread lug nuts/extended shank style lug nuts?
JR1
Joe
Missouri
These are 2025 TRD Pro 18” wheels with Mickey Thompson Baja Boss AT tires.
The tires are 265/65/18 which is almost the same size as the stock Geolanders at 265/55/20.
No lift or leveling kit.
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_1842-jpe
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_1838-jpe
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_1837-jpe
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_1841-jpe
Before (stock TRD Sport wheels)
20x8" inch machine finished alloy wheels
31.5" (265/55R20) Yokohama Geolandar A/T G015 tires
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_1780-jpe
bigbruse
robbie
va
2025 4runner
Wanted to bump up the OEM SR5 tires just a bit, which were 245/70R17 (30.5” diameter).
Installed 265/70R17 Falken Wildpeak AT4W tires (31.5" diameter) on the stock SR5 wheels.
Looking to buy the same size tire for my sr5! How do you like them any rubbing?
lb1606
FL
Before & After on SR5:
Tires: Falken Wildpeak 285/70/17 A/T4W SL
Wheels: Icon Alloys Recon SLX Satin Black 17x8.5 +25mm Offset
No lift
No rub
The Wildpeak AT4W tires are great.. they ride smoother than stock with a very slight hum. Not noisy by any means though.
2025 4runner SR5 no lift 285:70:17 Wildpeak AT4W tires on +25mm Icon Alloys Recon SLX 17x8.5 +...jpg
Any update if this wheel setup never had any rubbing at all? I would like to copy this setup because Icon wheels have a 95.1 center bore size but hesitant due to the +25 offset with this tire size if it will rub at full turn lock. No lift on mine either.
RyanMort
Ryan
Boulder, CO
2025 4Runner Off Road Premium
New 2025 Off Road Premium (Everest) - After Market Build.
2.5" ReadyLift
285/75/R17 Toyo Open Country - C Class
SCS Blaze 10 Wheels +20 offset
Tinted front windows
Ready to rock in Boulder, CO and Colorado excursions this summer!
Thanks to Corwin Toyota After Markets Team; Ryan. Highly rec.
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! after-
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! before-
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! side-1-
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! front-
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! side-3-
Michaelkael
Michael
Cantley, Qc - Canada
2025 4Runner TRD Offroad Premium - Underground
2.5" ReadyLift
Great setup ! ?
g0.0utside
2023 Bronco BadSquatch
2025 4Runner TRD Pro in Underground with Cockpit Red Interior
-295/70R18 Nitto Recon Grapplers
-Peak Suspension 1in top shim and 1in rear spacer
-Ceramic Coating
-Screen Protech film for Infotainment
Starting suspension measurements for the Pro was:
Front - 21 3/4
Rear - 22 5/8
After small lift:
Front - 22 3/4
Rear - 23 1/2
I am in love with this truck. I still have my 21 TRD Pro but this one is next level.
Looking great! question: Can you please post links for the exact suspension shims and spacers you used on your TRD Pro?
Cory39744
Cory
Virginia, USA
Looking great! Two questions: 1) How'd you score the red interior? I don't see that as an option on the Toyota website or anywhere else. It looks sick! 2) Can you please post links for the exact suspension shims and spacers you used on your TRD Pro?
I believe the red interior is an option on the site for the TRD pro. For me, I just found it on the web, called, and put my deposit down. I really like the color. Here are the links.
https://www.peaksuspension.com/product/2024-toyota-4runner-trailhunter-1-lift/
https://www.peaksuspension.com/product/2025-toyota-4runner-rear-spring-spacer/
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Underground 2025 4Runner TRD Off-Road Premium 6th gen build on:
Volks TE37xt 17x8.5 +15 Offset (Diamond Black Finish)
Mickey Thompson Baja Boss AT 285/70R17 Tires
ReadyLift 1.5 Front Lift Kit
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! fset-wheels-285-70-17-baja-boss-at-2025-4runne-
Walkaround video
JR1
Joe
Missouri
Walkaround video
Beautiful !!!!!!!!!!!!!
Michaelkael
Michael
Walkaround video
Beautiful, and thanks for the video, great idea !
So you’re able to run these with just a front 1.5” leveling kit ? Any rubbing ?
