Cyclical squealing / squeaking sound from front differential. Fix = debris removed & seals replaced
AZGOLD
AH
Prescott
2025 ORP 4runner
Cyclical squealing /squeaking from front differential area between 39-50 mph.
Immediately goes away when switched into 4HI, and comes back when 4HI disengages.
Thank god I havent done a lift, tires, wheels or anything yet or Toyota would certainly blame that as the culpret. Been there done that :cautious:
I`ll get the truck in to service as soon as I can
UPDATED WITH DIAGNOSIS & FIX
Ok, Heres the update:
Service dept were able to re-create the issue. ( chirping/squealing between 35mph & 45mph ) goes away when H4 is engaged.
Technician found " foreign material" between axle seal and replaced 2 seals 90311-47039 & 90311-47040 Type T oil
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
Sorry to hear that, please update the thread when you find out more.
AZGOLD
AH
Prescott
2025 ORP 4runner
Tennessee USA
F350
So, If I understand your description correctly, it's only happening in in 4WD Low? Not happening in 2H or 4H?
I need to go test my 4WD ASAP.
JR1
Joe
Missouri
Interesting. Foreign material could be anything other than gear oil and gasket material.
Dead Horse
Oklahoma
Pretty sure he means he's in 2WD when it's making the noise. 4Low probably won't be hitting 50 mph unless you've driven off a cliff lol
AZGOLD
AH
Prescott
2025 ORP 4runner
Sorry for any confusion. The noise only occurs in 2H ( normal driving ) The noise immediately went away when switched into 4H on the fly. Yes you can switch into 4H at 43 mph . If you are going to fast to do that, the truck will let you know.
I dont need any more detail regarding the diagnosis myself. I just wanted it documented in case there were any further issues. They told me Toyota Corporate was notified of the situation.
human_jed
CO
I’m having what sounds like a similar issue on a 25 ORP iforce I’ve just taken delivery of. Mine is more of a subdued howl from the front left, goes away when put into 4HI. Did the dealers debris removal and seal change actually fix the issue for you?
AZGOLD
AH
Prescott
2025 ORP 4runner
Yes . No more issues and I have about 3K more miles on it now.
