3/4 length rack that doesn't require sealant?
bbbradley
Bill
MA
Small, Medium, and Large
New 4Runner that needs a rack or rails for an Inno ski box, was ready to go with the Westcott, but come to learn that the installation requires sealant to prevent water ingress. That seems like a poor design that will require upkeep. What is it about the mounting that necessitates sealant and why did they do that and add a failure point?
I can't find any other 3/4 length (we have the moonroof) racks out there.
Sorry made a post but just noticed your talking about a 3/4 rack but they wouldn't let me delete it.
I have no experience with WCD 3/4 racks but the WCD full length rack uses the OEM rack bracket mount points which use sealant from the factory. As long as you clean the old sealant out and use a quality sealant you shouldn't have an issue.
bbbradley
bbbradley
Bill
MA
Does that mean the factory rack has built in leak points? Coming from a Wrangler where Jeep publishes a diagnosis & repair manual for water leaks I was hoping to never have to worry about it raining inside the vehicle. :D
bbbradley
bbbradley
Bill
MA
Factory vs DIY aftermarket is not even close to the same thing. Factory can install the rack from inside the bodywork.
Wandering Sagebrush
NE Oregon
2026 4Runner TRD Off Road
They can, but unless I’m missing something… they don’t. The towers are attached by bolts from above. A good install video to watch is by Backwoods.
spyder40
Indiana
2021 4Runner ORP
Sherpa doesn't use sealant and they don't leak but are full length. Solid strong rack and pretty quiet. Had one on my 5th gen and now my 6th gen
bbbradley
bbbradley
Bill
MA
Thanks, saw that one, but not keen on a rack over the moonrood. :(
bbbradley
bbbradley
Bill
MA
Didn't know that, I only wish Sherpa would keep the bars and knock a few hundred off the price. $1200 for a chunk of metal is a bit to stomach.
Get OEM ARB 3/4 style. Plenty of Trailhunter & Pro in my area selling take-off for less than $500.
pistol
OR
2026 Everest TRD ORP
Why not just run oem crossbars for the box?
If you're worried about removing the factory rails... don't?
I have kuat dek with an inno box and if you use the correct sealant it shouldn't be an issue.
2025 2026 4runner 6th gen 3/4 length rack that doesn't require sealant? 20260924_122822
xp0nex
2025 4Runner ORP
I will not do a roof rack ever again unless I really need it and there is no way around it. I had a Sherpa once on an older vehicle and that thing still leaked. Whenever it rained hard, I'd always find a puddle at my feet. Removed and re-installed several times and that never resolved it. Silicone was used at the end of the day to remedy it.
spyder40
Indiana
2021 4Runner ORP
I've had 2 Sherpas and taken them off/on multiple times to apply ceramic coating. Haven't had a leak yet. Only 5th and 6th gen though
