2025 TRD Pro rear hatch opened by itself
Charlie
Charlie
2025 TRD Pro
Since October, the rear, motorized hatch opens by itself. It’s happened 4 times. After the second time, I turned off the under bumper kick feature. Still happened 2 more times. I also stopped carrying the fob when I’m home in case the hatch button on it gets pushed accidentally by my house key. That hasn’t stopped the problem either, the fob had been untouched for several hours when it happened again. Anyone have thoughts about what the cause could be?
when does it open, under what operating or non-operating conditions ?
Charlie
Charlie
Charlie
2025 TRD Pro
It happens when it’s parked and locked, day or night. It is parked outdoors, no garage. At first I thought it might be critters passing under the rear bumper, so I turned that function off.
it’s very random, 4 times since October.
Charlie
Charlie
Charlie
2025 TRD Pro
2x before I turned off the kick function, 2x after.
Jakethewhippet1
Geneva, IL
2025 4Runner Off Road Premium
The kick sensor function only works with the FOB in your pocket.
That's weird and sux, I'd take it to the dealer before someone passing by takes advantage of that situation.
Unless the dealership has seen this before which I doubt or it would have shown up on one of the 4R sites your gonna have fun trying to figure that one out. I'd expect multiple return trips....
Good Luck and let us know....
if you are carrying your fob around, it has to be butt-dialing the fob
if you are setting all fobs down, lock them both out [sleep mode]
and keep them locked out
HOLD lock button on fob
while holding LOCK, press unlock twice and then let go of all buttons
FOB led should blink 4 times...blink blink - pause - blink blink
now your FOB radio is turned completely off* and cannot be detected by
the 4runner *FOB still has flea power [enough power to detect a new button press]
see if that changes anything
zgreen
Zach
Very strange! Hope you can find a fix!
Charlie
Charlie
Charlie
2025 TRD Pro
After about 6 months, the only workaround that’s worked is to leave the fob on a table or counter and also turn the fob off entirely (hold the fob lock button down while clicking the open button twice - wait for the red light to blink 4 times before you let go of the buttons).
