2025 ORP Gas Bilstein 6112/6100 help
Armbender
Will
halifax
2025 4Runner ORP
Looking for some guidance on the Bilstein 6112/6100 setup.
2025 ORP Gas
I’d like to get this setup to properly level the truck and get a better ride for daily driving.
I’ve seen setups with this on gear but the math isn’t computing for me.
Most people are running clip 4 which gives a 2.4” lift in the front. And for the rears sticking with OEM springs.
The ORP comes with a front rake of 1.5”. I don’t understand how you wouldn’t be squatting with the 6100s and OEM springs
I checked on Mudify and they have a kit that offers rear springs, but in Canada they haven’t come out yet.
Ideally, I’d like the 2.4” front lift and have zero squat. Thoughts, comments, recommendations are welcome
Thanks
Twisted
Oregon
5th Gen TRD -> 6th Gen TRDORP
I'm not sure who is saying the 2.4" setting in front and stock rear springs won't squat.
I have the the fronts at 2.4" and a 1" cornfed spacer in the rear with stock springs. It rides level until I put anything in back then it is debatable. I have the air lift helper bags that I want to install to keep it on the more level side and less squatted side when loaded with stuff.
For what it is worth, the Cornfed spacer is under $100 and they've been around a while. For some reason folks like to spend double that money on aluminum spacers.
