Rear Spring Options for Bilstein 6112
mallcrawler42
Antony
OR
2025 4Runner TRD Off Road
So I’ve done a little digging to see what rear springs I could pair up with the Bilstein 6112s with my non hybrid TRD Off Road. So far I’ve only seen options from OME (lift height unknown), Icon (0.75in lift) and Dobinsons (1.25in lift). Eibach has springs but those are the hybrid models.
Has anyone run icon or Dobinsons rear springs on their 6th gen with Bilsteins yet? I saw a post on here about someone running 5100s with OME rear springs. I was wondering if Dobinsons or Icon would have a higher or lower spring rate then the OME rear springs? Since I can’t find any info on them.
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
We also have rear coils that provide about 2" of lift and they're made in the USA.
Dobinsons and OME typically increase load carry capacity and have higher spring rates. Much of the time Icon is closer to stock spring rate unless their coils are marked as overland coils.
mallcrawler42
Antony
OR
I see that Dobinsons and OME have no added weight and a few different added weight options.
However If I were doing a 3in lift up front and the rear shocks allow for up to 1.75in lift…ideally what springs should I go for in terms of the amount of lift? I’m still relatively new to all of this.
