purplenomad
Drew
Chattanooga TN
2025 4Runner TRD ORP Hybrid
I was able to access the service menu on my TRD ORP Hybrid using the following method:
1.) Turn ignition to "on" (but engine is off)
2.) Set Power/Volume control to "off"
3.) Go to Settings -> Display and turn the Display "off"
4.) On the now blank screen "Swipe Left to Right" 5 times, then "Swipe Right to Left" 5 times.
Not as cool as "Engineering Mode" on my Kia Seltos, but may be somewhat useful. Share what you discover! :)
2025 2026 4runner 6th gen Service Menu Access Procedure (How-to Instructions) 23010-4a0fd55ce776f5ba0902463e898e88e6
quadna71
Delaware
2025 4runner
I wonder if you can put the parking brake into service mode from that screen? It would be helpful when it comes time to do rear brakes. Otherwise you'll need an OBDII scanner to retract the parking brake motors
FlyCook
Rick
Looks like you can turn off camera recording there?
it's only for the headunit itself, it's not vehicle functions
go ahead and look there is pretty much zero to do in there
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Has anyone been able to find out how to adjust the cameras? Im going to be swapping out grilles to the trailhunter version which moves the front facing camera to the top grille section.
AZGOLD
AH
Prescott
2025 ORP 4runner
There is no adjustment. There also isnt any such thing as a "profile setting" 🙄 Many on here have been spreading that nonsense too.
If you change your grille, you need the camera bracket made for that grille, so the angle of the camera is correct. Get it from Toyota or regret it
purplenomad
Drew
Chattanooga TN
Looks like some slight camera adjustments can be made within the service menu system. May help fine tune things after you get the right bracket.
2025 2026 4runner 6th gen Service Menu Access Procedure (How-to Instructions) IMG_3718
ngfilla94
Nathan
St. Peters, MO
Exactly what I was looking for, thanks!
ngfilla94
Nathan
St. Peters, MO
