purplenomad
Drew
Chattanooga TN
2025 4Runner TRD ORP Hybrid
I was able to access the service menu on my TRD ORP Hybrid using the following method:
1.) Turn ignition to "on" (but engine is off)
2.) Set Power/Volume control to "off"
3.) Go to Settings -> Display and turn the Display "off"
4.) On the now blank screen "Swipe Left to Right" 5 times, then "Swipe Right to Left" 5 times.
Not as cool as "Engineering Mode" on my Kia Seltos, but may be somewhat useful. Share what you discover! :)
2025 2026 4runner 6th gen Service Menu Access Unlock Procedure (How-to Instructions) 23010-4a0fd55ce776f5ba0902463e898e88e6
quadna71
Delaware
2025 4runner
I wonder if you can put the parking brake into service mode from that screen? It would be helpful when it comes time to do rear brakes. Otherwise you'll need an OBDII scanner to retract the parking brake motors
FlyCook
Rick
Looks like you can turn off camera recording there?
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Has anyone been able to find out how to adjust the cameras? Im going to be swapping out grilles to the trailhunter version which moves the front facing camera to the top grille section.
AZGOLD
AH
Prescott
2025 ORP 4runner
There is no adjustment. There also isnt any such thing as a "profile setting" 🙄 Many on here have been spreading that nonsense too.
If you change your grille, you need the camera bracket made for that grille, so the angle of the camera is correct. Get it from Toyota or regret it
purplenomad
Drew
Chattanooga TN
Looks like some slight camera adjustments can be made within the service menu system. May help fine tune things after you get the right bracket.
2025 2026 4runner 6th gen Service Menu Access Unlock Procedure (How-to Instructions) IMG_3718
ngfilla94
Nathan
St. Peters, MO
Exactly what I was looking for, thanks!
ngfilla94
Nathan
St. Peters, MO
nateanderson1990
Nathan
Alberta
2026 4Runner Platinum
Too bad it can’t be used to disable the 4Runner from beeping at me annoyingly every time I step out of the running vehicle with the fob in my pocket, or open or close the tailgate hatch.
That is the most annoying thing, did you ever find a way to shut it off?
RenoBravo
Reno, NV
No, no luck yet. I even sent $5 to “TheCareNut” (Toyota Master Mechanic on YouTube) and asked him if there was a solution but no response.
I really love my 4Runner, but between having to reboot the radio every time I remote start the truck and get in (to get it to pair with my iPhone) and that frickin nagging door beep, I’m not sure I’ll ever buy another one.
both issues seem like easy software fixes that could be downloaded to the system settings, but unless I am missing something, I don’t think Toyota is doing anything about it.
ngfilla94
Nathan
St. Peters, MO
You shouldn't have to reboot the radio to connect your phone after remote starting. If you go to your connected devices on the menu, just select your phone and it will send out the connection request/ping and it should connect right away. It's annoying, but that's my workaround.
this. once in a blue moon it won't detect the phone, so I go to bluetooth devices and just
hit the button again.
