Raptor Lights installed on 6th Gen 4Runner grille [DIY video added]
Eddson
EDDSON
Sacramento California
4 runner trail hunter
I bought these fr Amazon, super simple install. I tapped into the daytime running light wire. I tried tapping into the IGN3 fuse but it screwed up all the driving sensors so I tapped into the wire.
Hey buddy from where did you grab the DRL ?
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Installed these from Amazon today. Very clean install. The wires can route through the holes below the clip points for the engine bay cover. Used the fuse tap in the 10A IGN location. When the lights are off they're invisible.
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250517_084910
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250517_090354
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250517_090315
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250517_090533
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250517_090610
double RB
rhanjit
honolulu hawaii
2025 4runner sr5
you have no problem in tapping it in ign 10a? i just install mine but not yet fuse tap . dont know what fuse to link in. thank you
ngfilla94
Nathan
St. Peters, MO
The only thing I've noticed is that there seems to be some sort of system check the vehicle runs within maybe 30 minutes of turning off the engine (haven't done a deep dive to actually research yet) that applies power to the ign circuit. There's been two instances where I've walked out into my garage and noticed the lights on, but they turn off in less than a minute. Both of these instances were within a 30 minute window of parking it and I haven't seen them on at any other time. I'm not worried about it personally, just something to note.
Icculus
Adam
NC
2025 IC Trailhunter
So the Raptor style front lights aren't really my thing because in reality they a necessary legal requirement of a vehicle over a certain width, kinda like the similar roof mount lights on work trucks; specifically those exceeding 80" in width. That being said super kudos to you for a clean concise writeup and the fact they you printed your own brackets makes it even more dope. Cheers
ah4rsr5
Abraham
VA
2025 4R SR5
Is it bright? Can't really tell from the photos... I wouldn't want it to be dim and have it look cheap
Timmybung
Timothy
NH
I ordered and installed these from Amazon.
https://a.co/d/3dxbsF2
Overall quality is fine. Don't love how they mount, essentially there are clips on the back that clip (loosely) to the grill. I used zip ties behind them to make them really secure.
They look great from ten feet away but up close I don't love the plate that blocks the grill.
Edit: after posting this I realized I might have installed them wrong and that they should be 'behind' the grill. I'll have to check it out after work...
Subsequent edit: they do not Mount behind the grill.
Further update weeks later: One of the lights has started working intermittently, when you wiggle the wire on the back of the light it goes on and off. Don't bother getting these. If I already have one light starting to fail just a few weeks in I can't imagine the whole set is going to last all that long.
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250717_174927~2
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250717_174931~2
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250718_052520~2
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250717_193623
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 20250811_105608
toothpaste22
Ryan
Dallas
I would recommend the thinner ones with smoked plastic cover. It uses the red double sided mounting tape, with proper cleaning (rubbing alcohol) these things will stick well! Since they have smoked covers, they blend in really well when they’re turned off, unless standing out like yours is what youre after.
Flexte
PENNSYLVANIA
2025 4runner TRD OR Premium
StickerFab has an option and a very good install video.
papadop88
2025 4Runner TRD Pro
Ended up getting the ones folks in this thread purchased from Amazon. I'll upload the install video shortly.
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] IMG_0181
ggrant20
Atlanta GA
I LOVE my 4Runner…2.5” “ leveling kit” and Nitto Ridge Grappler 275/65 R20’s. No rubbing at all.
These look awesome, thanks for sharing the link!
Was curious, where did you get that red “TRD” badge on your lower grille? And did they have other color options?
Flexte
PENNSYLVANIA
I am a lot happier with the look and installation of the Amazin lights mentioned in this thread. Unfortunately I installed the ones from Hansshow originally. I can't believe they would send out an unfinished product and sell it for so much more money. Thanks again for the suggestion in the video for the cheaper but better ones off of Amazon
2025 2026 4runner 6th gen Raptor Lights installed on 6th Gen 4Runner grille [DIY video added] 1000045809
