- First Name
- John
- Joined
- Apr 28, 2025
- Threads
- 7
- Messages
- 295
- Reaction score
- 358
- Location
- Los Angeles
- Vehicle(s)
- 2025 4Runner TRD Pro
- Thread starter
- #16
I had the same initial thought about the Amazon ones being mounted with 3M tape. They’re actually perfect and they are absolutely uniform if you mount them correctly. So don’t worry about that at all. Plus they come with three different fuses as you see in my video. No reason or need to buy anything else to install them. The Hansshow ones clip in, are loose and will rattle. Plus the design of their housings do not match the design of the grill. It’s up to you, but they won’t last you long. Also, there isn’t a fuse box extender for the 6th gen yet but I’m sure it coming. You don’t need it though.I completely install them so hopefully they will return them after I take them out. This is my first 4Runner and this is my first time doing any type of work on any vehicle. They look really good in my neighbor even said the same thing it looks like they're stock. I'm just not happy with the connections. Having a bare wire wrapped around a boat isn't something I'm happy about. Also I had to go by butt connectors I didn't install them yet I was going to work on that this weekend. I think I'll take this as a learning experience and pull them out. The only issue now is that I have a slot dremeled into the side of my fuse box. I wonder if her fuse box extender would cover that hole up? Have you seen one for the 6th gen 4Runner yet I know they have them for the 5th?. It's not that much a good deal cuz you can't see it with the fuse box lid on. Thanks for your reply like you said they just aren't designed wel. I spent a lot of money buying different connectors and trying different things to get this to work so it's a lesson learned. I don't think I'm going to go with the stickers like you have just because my OCD would drive me crazy not having them perfectly lined up perfectly. I don't even mind them being loose because they fit in uniform. My biggest issue is the connections.
