vready
Vince
Hood River, OR
I just installed the ARB Twin Air Compressor in the engine bay of my TRD Off- Road Premium iForce MAX Hybrid, including the ARB Manifold Kit and ARB Universal Hose Coupler.
In order to make everything fit, I used this compressor mounting bracket from Bullet Proof Fabricating, which allows you to relocate the ECU modules and free up space.
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4815
The installation process was fairly straightforward and I just followed the step-by-step instructions on the BPF website, and the compressor install guides from ARB. It took about 2.5 hours from start to finish, including gathering up the required tools, removing the ECU bracket, mounting all the hardware, installing the new bracket, and reconnecting and testing everything.
Here are a few more photos to help you visualize the before and after.
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4779
This is how it looked when I started (stock 4Runner configuration)
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4781
I disconnected the battery and removed the ECU modules, which opened up a much bigger space.
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4783
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4792
Following the instructions from Bullet Proof Fabricating (a Canadian company BTW) I mounted the compressor and ECU onto their bracket.
Once I dropped it in and mounted it with the original factory bolts, it looked like this:
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4793
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4803
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4807-Edit
Next, I configured and mounted the ARB Manifold Kit on the ear off the left side of the BPF bracket:
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4811
Here are a few more looks at the install:
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4812
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4790
2025 2026 4runner 6th gen Installed ARB Twin Motor Air Compressor using BPF Mounting Bracket _W0A4813
Huge shout out to Phil Gragg at Offroad Toy Outfitters in Vancouver, WA for helping me source the parts, and giving me the confidence to undertake this one on my own. He's a great guy and a great resource for the 4Runner community!
J4Runner1
James
Nice. Thanks for the write up.
TurnerXC
Brad
Richmond, VA
2025 4Runner TRD Pro
nice work. I pulled my ARB out of my 2017 JKU when I traded it in on my TRD Pro. just been waiting for someone to come up with a mounting bracket for it..
elecfuyu
6G Platinum
Curious how you hook up the power since the battery is in the back.
Did you already ran a dedicated power source from the battery to the engine bay?
vready
vready
Vince
Hood River, OR
elecfuyu
6G Platinum
the sdhgooffroad looks nice.
Wish they have one coming out soon.
ropdykex11
Rich
Portland, OR
2025 4Runner TRD Off-Road
@vready how did you wire power? Looking to replicate your process exactly. Any concern with the compressor drawing battery power even when the vehicle is off?
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Compressors get pretty warm. Are you worried at all about this causing any damage to the fuse box next to it?
T_Pomp
Anthony
Illinois
Engines also get warm
Understood but it’s not all concentrated in one specific area. I guess your answer indicates it hasn’t been an issue for you? Have you used it much since installing?
ropdykex11
Rich
Portland, OR
Hahaha sorry I don't mean to be a smartass.
Two things:
1. I actually installed the Rough Country twin compressor instead. It was significantly cheaper, and includes a protective shroud with an included cooling fan. No problems whatsoever. BUT the mounting plate required modifications to accommodate it (holes were slightly off) and the compressor protective shroud also needed to be cut a bit to fit under the hood.
2. I only finished the install the other day, and have only tested it in the driveway. Everything seems to work fine, but definitely haven't put it under 100% duty cycle in hot conditions. (I live in Oregon and it's cold right now, I don't expect heat issues anytime soon.)
Good luck!
elecfuyu
6G Platinum
I have same setup.
I use the air to clean the engine bay after FSR run.
Blowing air for 15min straight no issue.
I doubt anyone will use the compressor for 15min straight when pumping air into the tire.
