buhay4runner
Leo
San Francisco. CA
2025 4runner
18" Method 320 18x9 6x5.5 +18 offset bronze finish
Falken Wildpeak A/T4W All Terrain 275/65/18
Gorila M14 1.5 ET lug nut
Installed on my Underground 2025 SR5. I'm going to a certain look. I'm not trying to have look off-roady at the moment. This is pretty much my daily. But I do want that little poke. No rubbing but pretty close to the mudflaps when turning all the way. I don't want to remove the mudflaps. Not for now at least.
I will install Rought Country leveling kit soon.
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. Bronze Method 320 18x9 (6x5.5) +18 offset w: Falken Wildpeak A:T4W 275:65:18 installed on my U
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. 20250421_152831
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. 20250421_153553
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. 20250421_145555
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. 20250421_145550
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. 20250421_145544
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. Bronze 18%22 Method 320 18x9 (6x5.5) +18 offset w: Falken Wildpeak A:T4W 275:65:18 installed o
Shawn_1121
Shawn
Hudson, NH
25 Sport Premium
great post. im kinda in the same boat. I have mudflaps and dont want to take them off also. plan on doing the RC lift kit. I have on order 18x8 +45 off set wheels and have been going back and forth on what size tires to get... either 275 or 265 both are 70/18
Any insight?
JR1
Joe
Missouri
I’m thinking about 265/70/r18 for my Sport. I have OEM mud flaps and I am pretty sure that they won’t rub. Should I chance a 275/70/r18? Anyone know for sure?
Rellims
Sean
ORP - Underground
I run 275/70/18 and the mud flaps will rub. Mine were taken off as well as the part behind it, I think it's called safety something. They also rubbed at full lock in the front very slightly so I pushed in the liner to give them clearance. Will install the rough country 2in lift in a few weeks and won't be an issue but stock 275/70/18 do rub slightly. Offset does make a difference as well, mine at +18.
Rear of the front tire with flaps removed and safty thing removed
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. IMG_7611
Front of front tire at full lock before i pushed the liner forward.
2025 4runner 6th gen Bronze Method 320 18x9 (6x5.5) +18 offset w/ Falken Wildpeak A/T4W 275/65/18 installed on my Underground 2025 SR5. No lift. IMG_7612
JR1
Joe
Missouri
Thanks. I’ll go with the 265/70/18. I don’t want to lose my mud flaps as they are protecting the body because we travel on a gravel road everyday. I appreciate you.
buhay4runner
buhay4runner
Leo
San Francisco. CA
2025 4runner
I was going to show you Relim's post actually. Beat me to it. You're going to install rough country leveling kit correct? I think you should be ok after. In my opinion, 265/70/18 still rub either way without the lift. 265/70/18 either way will be taller. As far as looks, 265/70/18 might be pushed in more because of your offset. I was originally deciding to go with 285/65/18 instead of 275/65/18. But I wanted that little poke. And I'm glad I stick with 275 because I got about close to an inch poke with +18 offset. If you want thr wider look, I would go with 275. But do it after the lift. I originally thought about doing both at the same time. But I held off on the RC leveling kit because I wanted to see how it look first. Now I want the 1.5 lift.
My opinion, I would go with the 275/70/18 if you want to at least have that flushed look.
Go check Mjmotorsports808 on IG. They're based off hawaii. And thier build is the reason why I went with 275/65/18. It will at least give you some ideas.
Shawn_1121
Shawn
Hudson, NH
25 Sport Premium
I ordered the Rough Country 2" Levelling kit + 18x8 +45 ET wheels with the 275/70/18 tires. I should be good with the Mudflaps still being installed after all the posts I have read. The setup is a truly 33in and the rims should be sitting pretty flush with the fenders.
buhay4runner
buhay4runner
Leo
San Francisco. CA
2025 4runner
With the leveling kit. IMO, should be good. I'm happy with the 32 for now. But my next tire change, I might try 33's. I think 275 will be perfect instead on 265. Specially with yout offset. Mine with 275 +18 offset is poking about an inch. With yours, it should definitely sit flushed IMO. Can't wait to see what you did. I do have a leveling kit now, I might install it next week.
