FoRunna
Atlanta, GA
Well, this is exciting. The 4Runner went into the shop last week to install the TEQSPORT T550X turbo. This is a totally new design drop-in ball-bearing turbo for the T24, not an upgraded CHRA in a stock housing.
Modifications up to this point are the following;
SXTH Element Intercooler
AWE 0FG Exhaust
TEQSPORT Intake (Pre-Production)
TEQSPORT Turbo Inlet (Pre-Production)
TEQSPORT Ecutek Tune
The dyno below is from a few weeks ago with the setup above, when ambient temps were around 95 degrees. (Really speaks for how well the intercooler is working, way to go SXTH!)
Making mid 300's and over 400wtq is pretty satisfying; that's about 80whp and 90wtq above the baseline. It'll be cool to see where this lands with the bigger turbo.
Updates coming when available!
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) image (33)
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) 774513705_10165038315859266_6184575379191654197_n
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) 776222438_10165038316294266_8445950625143850752_n
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) 775087364_10165038316549266_5901463090570995373_n
pistol
OR
2026 Everest TRD ORP
love to see it!
samsamdar
Samy
Dallas, TX
2025 TRD ORP
Dang I didn't even know Ecutek supported our platform yet. So you're doing a full custom flash tune on it?
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
This is the way to do it. Hybrid turbos built in the stock housing are are short term measure and not ideal. Great work Teqsport!
FoRunna
FoRunna
Atlanta, GA
Yep! They've been on the platform for a little while. Pretty cool.
It'll get a full tune on the dyno over at Z1 / TEQSPORT.
FoRunna
FoRunna
Atlanta, GA
It's good stuff! We need to try and get you one of these to try :cool:(y)
FoRunna
FoRunna
Atlanta, GA
It's done, and the numbers are in...we made a respectable 411whp and 435wtq! đź’Ş
When this thing was stock, it made 271whp and 342wtq on the same dyno, which means that with this setup we've picked up 140whp and 93wtq, which is HUGE!! Our original baseline was completed when ambient air temps were in the 30's, whereas yesterday we were at about 95 degrees outside. This is a testament to the effectiveness of the SXTH Element Intercooler, and has me pretty excited for fall weather.
We're near the limit of 93-octane fuel, and it has more potential, but there's a restriction in the charge air system that's holding it back as well. More updates to come....
(Dyno below shows high-boost and low-boost maps)
First impressions driving it are kinda what you expect. Coming from stock power to this is pretty astounding. Having had a few built Corvettes and other fun past cars, I can confidently say that a 4Runner has no business being this fun and looking this stock.
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) image (9)
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) 1000036275
2025 2026 4runner 6th gen 411whp / 435wtq upgraded turbo 6th Gen build - Installing the TEQSPORT T550X Turbo & Ecutek Tune (Bolt-On Ball Bearing Turbocharger Upgrade) 1000036279
odins_beer'd
Not a want but a need. I have the Sxth Element intercooler, OTT spicy tune, intake + snorkel, KN63 upgraded turbo inlet, and AWE exhaust. Curious to know if if that would be enough to support the platform.
HVLA
Lexus
Basically what he has.
odins_beer'd
Right, I should have clarified. My main concern is the tune. He has the teqsport tune, and considering they are the ones helping him install I'd imagine its a custom tune of sorts. The clarity I guess I'm looking for is if I would have to go to OTT for a custom tune or reflash for the teqsport tune
FoRunna
FoRunna
Atlanta, GA
Solid setup tbh. You'll have to toss the turbo inlet and get a TEQSPORT inlet, it won't work with the larger T550X compressor housing. I'm also not sure if OTT supports custom tuning, probably worth checking with them. Otherwise, you're solid!
Edited to add: (we both responded at the same time)
Right, I should have clarified. My main concern is the tune. He has the TEQSPORT tune, and considering they are the ones helping him install I'd imagine its a custom tune of sorts. The clarity I guess I'm looking for is if I would have to go to OTT for a custom tune or reflash for the TEQSPORT tune
It is a 100% custom tune. To be transparent, I actually work at TEQSPORT. We offer tuning support but it's totally possible OTT may support custom tuning. If not, that's something TEQSPORT can certainly do.
tipsyjam
Hawai'i
2024 Tacoma TRD Sport
Is the restriction the throttle body inlet elbow? I noticed there was no mention of an upgrade to this in your build list.
Would be interested to see, if this is the case, how much additional power can be made with the increased efficiency in the intake tract.
Just installed the AMS throttle body inlet elbow on my Tacoma and even without a tune to take advantage of it or really any other intake modifications other than a TRD Pro intake - it is clear the truck likes it.
Been watching for the Teqsport turbo inlet elbow patiently and am interested in the new turbo as well. Thinking the turbo elbow will pair well with the throttle body elbow and a high flow downpipe even with the stock turbo. Excited to see what you folks come up with.
