Need Part Numbers for the Bump Stop Tower that will work on the 6th Gen
FloridaPhotog
Jon
SW Florida USA
2026 4Runner
I've seen that the bump stop towers for another model are compatable with the 6th Gen 4 Runner. Does anyone happed to know the parts numbers?
3rdRunner
Bill
Part numbers:
Driver Side: 51604-60060
Passenger Side: 51603-60060
Frame Bolts (6): 91674-N1030
These are for either LC250 or GX550. We have the same frame, TNGA-F, and they bolt on to threaded holes directly above LCA - 2 on the side, 1 on the bottom of frame.
2025 2026 4runner 6th gen Need Part Numbers for the Bump Stop Tower that will work on the 6th Gen IMG_0247
Fishing
New York
Does: Driver Side: 51604-60060, Passenger Side: 51603-60060 come with the rubber stop? or only the bracket? Thanks
Part numbers:
js_panda_rnr
shine
Seattle
How much (if any) up travel does this bump stop take away?
3rdRunner
Bill
Just the brackets. You’ll need (6) frame bolts as well 91674-N1030. I used Durobumps - DBF17T. You can get them from Durobump (I know…duh) or I got them from SRQ Fabrication - they had some in stock.
