A Cautionary Tale About Aftermarket Accessories—and an Expensive Unexpected Failure
bakutheleo
2025 4Runner i-Force Max
By "adding 10A load to the original ignition" meaning to the power coming to the fuse block? That is what I am trying to make clear to myself. If that, I agree. That extra current, though, should not be pulling through the original fuse.
CAMTuning
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
you're not wrong, and that's where the sequence of events is a bit hazy. Regardless, the customer claims that fuse was indeed blown, and it coincided with the poor running and eventual stalling of the 4runner.
Lamuncha
albert
new england
2025 4 runner
Would be nice if the admin folks could keep this current. IMO it is must reading.
Apply's to every aspect of new vehicles, electrical and mechanical.
Thanks for the post.
Gator 22
Florida
2021 TRD Off Road
So in the long run, with the new down pipes and new tune, a tad more power?
Nice sleuthing Mr Holmes.
CAMTuning
CAMTuning
Cam
NM
Quick update on this 4Runner:
The owner received his FaF Race high-flow catted downpipe, installed it himself, and found visible damage to the factory catalyst during removal.
After the new downpipe was installed, we reviewed the data and made the final calibration changes for the new hardware.
It is now running and performing correctly again, and he is back to enjoying his 4Runner.
josiahg52
Josiah
A fuse tap improperly installed could load the tapped fuse with its design load plus the added circuit, therfore causing it open on overload. I personally don't use them but they're merely "acceptable" when used in conjunction with a relay which separates the added accessory load from the tapped fuse design load. In general, I rank them only slightly above quick wire taps.
Twisted
5th Gen TRD -> 6th Gen TRDORP
Not that I needed another reason to despise raptor lights on Toyotas but I can sarcastically add this to the list.
(I don't actually care what others do to their own rigs. If they want to install raptor lights it makes it easier for me to profile them.)
I run raptor lights,
ready, set, profile me..... :)
