Need suggestions for new amp placement + subwoofer setup
Yoli
Yoli
Portland, OR
Hey all, I just took ownership of a 26 ORP a couple days ago, and I'm already planning the first upgrade - Gotta have my bass. I have a 07 4Runner Ltd that has a 12" box sub + RF amp under the passenger seat that has given me no problems for almost 20 years.
With the ORP, I'm having some trouble figuring out where to put the amp. I looked up slim line amps, possibly the Skar SK-M5001D with a matching ported 12" sub. Even with the amp dimensions at 9x5x1.75 height, I can't seem to find a good spot to put it. I cut some 2x6 lumber into 8" length and threw it under the passenger seat and the seat cables and components definitely hit it, and I'd still need about 3/8 more height over the piece of wood, so that doesn't seem feasible. I might be able to remove some of the carpet/fluff and attach it to the body, but I'd need to pull out the seats to verify that. Plus the air vent is there and I really don't want to lose that.
I'm thinking about mounting the amp to the back drivers wall, right behind the wheel well - like in the picture. It would be visible and it's a bit of a distance to run power to, but it's definitely easiest. Not sure about drilling into the side panel, but some gorilla 2-sided tape should hold it there for 100 years.
One other question I had is about the actual components I need. Forget the Sub/speaker for a moment. I've been doing some reading and I think I need the Taco Tunes Harness going to a LC2i Pro, then to the Amp. Does that sound about right or is there something better/more cost effective. The Taco Tunes harness and LC2i can likely mount under the drivers seat next/near the stock amp - at least according to this video:
I've priced it all out and I can likely do it for under $700.
What do you think about this setup?
2025 2026 4runner 6th gen Need suggestions for new amp placement + subwoofer setup sub-mount-l-sid
Brian Day
Brian
Empire MI
Taco Tunes works great and does fit under the drivers seat . You will have to remove seat to hook up the harnesses . You'll need access to the LC2i for tuning.
There is space under the rear floor mat for the amp , easy access , 2 10 mm bolts and 3 clips to remove floor .I ran the power cable from circuit breaker at battery under the plastic next to the seat to the back .
I did a down firing subwoofer from Crutchfield because the dog rides back there.
horbit
DFW
If you didn't get the hybrid, you can try sticking it under the panel floor.
RoketRebl
Brian
PNW
2026 4runner
This is where I put mine, it looks like you don’t have a hybrid, so I’m unsure what kind of storage space there is.
2025 2026 4runner 6th gen Need suggestions for new amp placement + subwoofer setup IMG_1438
2025 2026 4runner 6th gen Need suggestions for new amp placement + subwoofer setup IMG_1270
Darkchief22
Don
Westchester, NY
One day when im bored Ill try something silly like 2 or 4 8" subs where you have the amp hidden. BTW where are you getting your rca input from?
RoketRebl
Brian
PNW
2026 4runner
I installed the Beat-Sonic ENA-3T3 for RCA and remote, but due to my inability to fully read the description, I didn’t realize that you had to control the amp volume separate than the head unit volume, I guess it’s a JBL only thing. So I tapped into the factory subwoofer with a LOC, but I’m still using the beat-sonic for remote.
2025 2026 4runner 6th gen Need suggestions for new amp placement + subwoofer setup IMG_1437
Yoli
Yoli
Yoli
Portland, OR
I haven't pulled out the carpet in the back, but are you saying there's some extra room under the floor "rear floor mat"? Even on a non-hybrid version? Please tell me more about this and pics if you have them.
Brian Day
Brian
Empire MI
Only the non-hybrid has space under the floor .
Someone needs to come to the rescue with a solution. There is a little bit of a well. I would gladly spare some cargo room and raise the floor up for some storage. There’s some room on the driver‘s side to make some sort of filler piece.
Yoli
Yoli
Yoli
Portland, OR
Wow, I didn't know about that. I'm wondering now if the zero airflow would be a good choice for the amp in that space. Even with fans, there's got to be some exhaust someplace. I'll take a look tomorrow and see what I can come up with.
Brian Day
Brian
Empire MI
You could always put a 12v computer fan in there . its all open up into the side panels . No storage but it would provide airflow .
Yoli
Yoli
Yoli
Portland, OR
Hmm.. I think I'm going to go with my original idea and leave plenty of slack in the wires and see how it runs. If it seems like it's not getting too hot, then I'll move it in there. It's a bit of a chore to get in there. I have a cargo mat, dog crate + a future sub enclosure in the back of mine, so all that has to come out if I need to tweak it. I'll run it outside for a bit to get the settings where I need it, then might relocate it there.
I'm not sure where I see it's open into the side panels. It looks like just a cavity that is sealed when the floor is put back on. PC fan isn't a bad idea, but it would just be recirculating the air inside that cavity.
viper2788
Daniel
PG County, MD
2026 TRD ORP
Welcome! I'm pretty new here too and have been trying to figure out how to replace the subwoofer myself for the past month or so. Currently, I'm going with:
1) Beat Sonic EAZ-C02 Power Seat Cable Harness - maybe I should get power direct from battery? Good for 280W.
2) Taco Tunes harness package
3) AudioControl ACM-1.300 - instead of the LC2i, does the same thing but has a built in 300W amp! Should be small enough to fit under the seat or maybe light enough to secure to the underseat harness bracket
$) Kicker 48CWRT84 - should fit in OEM subwoofer location - parallel wiring gives me 2ohms, but you could just buy the 2ohm version
I've got most of the parts but waiting for the ACM-1.300 as it'll be replacing my LC2i. My original alpine amp barely fits under the seat so I've been putting this off... hoping to install it all soon. In any case, keep us posted!
