Need Aftermarket Storage Solutions for Cargo Area
Vincenzo
Southeast
Someone needs to come to the rescue with a solution. There is a little bit of a well. I would gladly spare some cargo room and raise the floor up for some storage. There’s some room on the driver‘s side to make some sort of filler piece.
2025 2026 4runner 6th gen Need Aftermarket Storage Solutions for Cargo Area IMG_1271
2025 2026 4runner 6th gen Need Aftermarket Storage Solutions for Cargo Area IMG_1272
Maximus4R
Adam
Nashville
Agreed. I sort of wish I had gotten a hybrid for the flatter floor and storage tbh.
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
that is the dumbest thing I've heard this week....... I wish I had 6cubic feet less of storage because it allowed 2 cubic feet maybe of storage.
4Runner-Dan
Boston
How did you remove the floor above this well? Fasteners are not apparent.
Hacksaw
az
2025 4runner TRD-ORP
Regardless of the well below the floor, I have to think there's a lot of dead air space inside the big wasted outgrowth of interior plastic that Toyota created just to accommodate cupholders for the small number of 4runners that have a 3rd row kiddie seat. On both sides.
Using a zoomed portion of Vincenzo's photo:
2025 2026 4runner 6th gen Need Aftermarket Storage Solutions for Cargo Area 4runr-rear-drvr-storage-cutout
If someone were brave enough to take a multitool and cut out an opening like I show here in the black area, a 3rd party could make a plastic storage insert that slides in (leaving about 1.5 inches of margin all around the cutout so the storage insert has a surface for a flange to bond to).
Seems like the only thing that would be inside this dead air space would be the sheet metal for the wheel well, at the bottom. And this storage insert could even be shaped so that it slides in with more storage area toward the front of this air space (like the yellow arrow). The access door could just be a pop-in/out panel as long as it had some rubber insulation so it doesn't vibrate.
If reasonably priced, the creator of this aftermarket storage bin would probably sell a kit to nearly every 4runner owner that doesn't have 3rd row seats--which is most 4runners.
It would even be useful if the creator of this only made it for the driver's side since it seems like a good amount of space--probably 3-4x the center console storage space.
OR: Alternatively, maybe the top cupholder portion is just snapped in place, and some sort of top-loading drop-in storage could be done.
LLL1990
Toyota Camry and Ford F-150
That's not wasted space that was created for cup holders, that's the wheel well. You know how the rear wheels have lots of articulation when going off road, guess where the tire goes when it's up high in the body.
Vincenzo
Southeast
This whole area could’ve been storage
2025 2026 4runner 6th gen Need Aftermarket Storage Solutions for Cargo Area IMG_1273
4Runner-Dan
Boston
Thanks! You pull upward on the rear of the floor panel to release the rear 3 clips?
Hacksaw
az
I'd be surprised if the top of the wheel well sheet metal went much higher than the bottom of the cutout I drew in. The gas filler tube may take up some space inside this area though.
Vincenzo
Southeast
It appears that there is some dead space behind the lug wrench compartment. I will most likely cut out. Stay tuned.
2025 2026 4runner 6th gen Need Aftermarket Storage Solutions for Cargo Area IMG_1275
Maximus4R
Adam
Nashville
Does seem objectively dumb but stay with me… The flatter floor would be so much nicer for me and easier for my two dogs too, at least I’m guessing it would. They’re older and not appreciating the seat height difference in the back. The height to jump in isn’t the issue but they haven’t figured out what to do with the mismatched levels. When I have them in the just cargo area they complain the whole time since that’s not what they’re used to.
I thought the hybrids had a few storage compartmented though, no? I don’t have an issue with needing more storage or carrying space for large items, more so would love some options for smaller gear and things.
Mad Ghost
Wylie Texas
The hybrid does have a little storage bin.
