SwitchPros Keypad Mounting Bracket from Westcott Designs
vready
Vince
Hood River, OR
I recently installed a SwitchPros 9100 8-switch keypad in my 2025 TRD Off-Road Premium Hybrid. I'd been waiting for the custom mounting bracket from Westcott Designs to be released so I could integrate the keypad into the dash with a truly OEM+ appearance. The keypad sits above the other buttons to the left of the steering wheel, and the keypad is always visible from the driver's position, and easily reachable at all times. Actually far better than where the factory AUX 1-4 switches are located.
2025 2026 4runner 6th gen SwitchPros Keypad Mounting Bracket from Westcott Designs _W0A2272-Edit
Westcott Designs describes their keypad bracket as being, "designed specifically for a clean and seamless installation, this bracket ensures quick access to the buttons and controls for all your accessories wired to the Switch Pros module. Milled from Billet Aluminum with precision craftsmanship and finished with Type 3 hard coat anodizing. This bracket is designed to fit perfectly within the Toyota 4Runner interior, offering a professional, factory-like appearance."
... and I've gotta say, it feels super solid and integrates beautifully into the dash layout.
The installation process is very straight-forward. You remove the plastic cover onto which the keypad is mounted (retained by three self-tensioning clips). I was able to remove it by gently prying with just my fingers on the lower-left corner and gradually easing it out. Once removed, you need to drill a 1/2" ⌀ hole in the plastic panel as well as the plastic beneath it to route the keypad communication cable forward through the firewall.
2025 2026 4runner 6th gen SwitchPros Keypad Mounting Bracket from Westcott Designs IMG_1435
Since the cable run is such a short distance, I recommend going with the 5' Communication Cable from SwitchPros. There's plenty of room to coil up any excess cable behind the switch panel. I just zip-tied my extra cable into a loop and then zip-tied that loop to an unused metal bracket on the left side of the panel to keep it secure and out-of-the-way.
Westcott doesn't have the 4Runner keypad bracket listed on their website quite yet, but you can call them at (480) 750-8747 to place an order. The part number is 6G-4RUNNER SWITCH PRO MOUNT (Part # 95233-4RUN6G).
2025 2026 4runner 6th gen SwitchPros Keypad Mounting Bracket from Westcott Designs _W0A2832
Highly recommend!
dgorman
Evergreen Colorado
2025 4Runner TRD Premium
Highly recommend!
Got mine but what are the other threaded holes for in the face? There are no instructions or additional hardware.
Garrett_A
Garrett
San Antonio, TX
2025 4 Runner - TRD Off Road Premium
Do you have any pics of the fuse block/relay panel and bracket in the engine bay?
vready
vready
Vince
Hood River, OR
Sure. Here are a couple of photos of the SwitchPros control module mounted to my SDHQ 12v power relocation bracket (https://sdhqoffroad.com/products/25-4runner-sdhq-built-under-hood-power-solution-kit) which sits over the master brake cylinder.
2025 2026 4runner 6th gen SwitchPros Keypad Mounting Bracket from Westcott Designs _W0A4692
Here's where all of my accessories terminate in a bus block, before being fed into the SwitchPros controller. I'm using Blue Seas Systems hardware for the bus block terminals and negative ground.
2025 2026 4runner 6th gen SwitchPros Keypad Mounting Bracket from Westcott Designs _W0A4695
The custom bracket for the bus block was custom designed and fabricated by my friend, Phil Gragg over at Offroad Toy Outfitters (https://offroadtoyoutfitters.com/). Designed in CAD and produced by SendCutSend (https://sendcutsend.com/) with a powder coat finish.
Garrett_A
Garrett
San Antonio, TX
Much appreciated and thanks for the quick reply!
bobholthaus
Bob
St. Louis MO
Jeep JL-370 AEV Diesel
Damn this is a clean install. Will he make that plate for others, and can you please post your exact parts you used (if you haven't already)? I'd like to duplicate your setup on my rig.
vready
vready
Vince
Hood River, OR
bobholthaus
Bob
St. Louis MO
@bobholthaus - he would definitely produce that plate for you. Just contact Phil at Offroad Toy Outfitters (https://offroadtoyoutfitters.com/). The plate for the wiring bus piggy backs off this mounting bracket for the ARB twin motor air compressor:
https://www.bpfabricating.com/produ...Csn34k0U0ivROWA1HeAybz1PUw_iW30n_Bom1kGvLQVRU
You can read my in-depth post about it here:
https://www.4runner6g.com/forum/thr...r-compressor-using-bpf-mounting-bracket.3936/
Thanks man! I appreciate all of this.
