Climbandroll
Va
Based on some posts in other forums and around the web, I gather that the 5th gen 4WD had 6 zerks (3 front [one slide yoke + two joints], and 3 rear [one slide yoke + 2 joints]).
On my 2025 TRD ORP:
Rear shaft:
I don't see any zerks for the rear slide yoke. It appears to have a boot/sleeve, so seems greasing the rear slide yoke would require removing the boot / dropping the shaft to expose it. I found one zerk per joint at each end of the rear shaft, so seems the rear has 2 total zerks.
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_130821_001
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_130833
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_130914
Front shaft:
There appears to be a zerk for the slide yoke on the front shaft, and one zerk per joint at each end, so 3 total (one slide yoke zerk; two joint zerks).
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_132302
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_132824
2025 2026 4runner 6th gen Drive shaft (propellar shaft) grease zerk fittings - 4WD (TRD ORP) 20250717_131044
So that is 5 total zerks (3 front + 2 rear).
At ~7k miles, I'm not in a hurry to grease the slide yokes. The front has the zerk, so easy enough (except my skid plate is in the way). But for the rear slide yoke, the boot would need to be removed to expose it. Also could require dropping the shaft from one end or the other, and marking to ensure it goes back to the same exact alignment from which it came, and it will be messy. I am hopeful (curious) that it was sufficiently lubricated at the factory to wait for me to figure out what I don't know. I also understand that too much grease there can create pressure, so the front slide yoke which is easily done via grease gun on the zerk will only get a 1/2 pump or two.
Anybody else getting into this yet on a 2025 w/ 4WD? What am I missing and/or wrong about?
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
I just got a greese gun for my trailer and i was curious about the fittings under these. Ill have to give it a look but i feel like you got it all. Most cars dont typically have too many fittings on the oem parts
cats4lyfe
Molly
Whitney, Texas
2025 ORP
Were you able to get this figured out? I just got a 2025 ORP and am wondering the same thing. Never driven a 4x4 before and somewhat intimidated by greasing these myself.
AdFour
Washington
What kind of grease would you recommend? AMSOIL 100% Synthetic Multi-Purpose Grease??
Any conclusion on the number of Zerk fittings? I don't have ramps anymore and may not be able to get under the SR5. Sound's like 2 Zerk's on the rear shaft plus a sealed Slide. Then 3 for the front including the slide yoke - Per original OP's excellent pics and description. Why in the heck would they make the front slide yoke serviceable and the rear sealed?
Its a bit disappointing the rear Slip Yoke seems sealed with clips. I wonder if the slip yoke greasing is in the Toyota service schedule or is it a non-maintenance item and only messed with if the boot is damaged?
I understand from other 4WD vehicles, the slip joint uses a different grease too. On an older Ford super Duty, it uses a special PTFE lightweight grease. Using regular grease can cause issues. Does anyone know what Toyota are recommending for the front slide yoke. Same as the joints or different like some vehicles. I am not willing to touch the front slide yoke until I can find out.
Thanks....
Climbandroll
Climbandroll
Va
Any conclusion on the number of Zerk fittings? I don't have ramps any more and may not be able to get under the SR5.
Its a bit disappointing the Slip Yoke seems sealed with clips. I wonder if the slip yoke greasing is in the Toyota service schedule or is it what many claim, "sealed"?
Maybe the rear slip joint does not need to be regreased unless the boot is damaged? I understand from other 4WD vehicles, the slip joint uses a different grease too. With paved road only use, maybe its not needed?
Greased rear drive shaft (propellar shaft) joints, front joints, and front slide yoke (zerk fitting exists only for front; no zerk for rear slide yoke as it is booted).
* Front slide yoke: Under pressure so not much needed here and too much is bad. Couple short pumps from mini 3oz gun with general purpose grease. I used the Multi Purpose Lithium Base Lubricating Grease that came with the mini 3 oz grease gun. I gathered mixed info from lubricant specialists as to whether grease for slide yokes should contain molybdenum disulfide. I took away that lubricating it at all is better than never, but too much is bad. I found a custom driveshaft vendor that preferred calcium sulfonate which seems to be suited for applications where potential water exposure exists. Rabbit hole.
Did not grease rear slide yoke (boot covering so must be dropped to service/grease). I may do this later in life.
I used this for the joints:
Valvoline Multi-Vehicle High Temperature Grease
Part No. VV615
extreme pressure / high temperature 0°F to 375°F
NLGI #2 Grade GC-LB Lithium Complex EP
For disc brake wheel bearings, suspension systems, universal joints, steering linkages and chassis.
shine
Seattle
Repair manual calls for "Lithium base chassis grease NLGI No. 2"
Gerardo
Gerardo
PNW
@Climbandroll Thank you for sharing this information!
I'm closing in on 7K miles and have started to get curious about lubricating propeller/drive shafts. I'm a DIY newb (did my own oil change for the first time at ~4.5K miles), I'm trying to learn about what sorts of maintenance are good DIY efforts. This one seems to land in the DIY zone where I feel comfortable exploring.
My research returns lubricating every 15K miles, or 5K miles if you off-road. Does that map to your (and others') experiences/expectations?
I have no trust in dealerships to properly do their job (they used the wrong oil and under-filled with only 4.4 quarts when I had them do a break-in oil change at ~1.3K miles), so I have no clue if they even lubricate propeller/drive shafts as part of their maintenance every 15K, if we have to ask to have them do it, if they do it right, or if they even know about it!
Thank you!
ShotsFired
Gary
Fairview, pa.
2025 Toyota 4Rummer TDR
Thank you!
And they won't let you watch either. An insurance company rule ?? Bullshit in my opinion
xztauri
2026 4Runner
Car Care Nut posted a recent (May 13) video on our 4Runner cousin, the 2026 Land Cruiser, in which he expressed appreciation that there were zerks (at 13:16 in the video). He stated that a manual grease gun won't produce enough pressure to get lubricant in these particular zerks, and an electric grease gun is needed. Never having done it on my vehicle, I can't say if this is always true.
what are you on. manual guns work fine. is he referring to some cheap gun ?
my gun has a screw-tightened head and can pump up any driveshaft zerk.
electric can eliminate the fatigue of pumping against a tough zerk sure, or if your gun nipple is cheese
