ArgoZ
Ontario
2025 TRD Pro Mudbath
60 bucks Canadian for powder coated tow hooks, love how they look compared to the black that mine came with… putting them on tonight
Cool idea, let’s see them installed. Since we cannot get the rear tow hook in Canada, this might be the way to go!
4cyl_runner
Rick
Arizona USA
Tacoma TRD OR, 2026 4Runner
I attached a cheap step from amazon today. I will repaint it with truck bed paint next week to make it look better. I alwo removed the plastic air dam on the front.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260419_210501
SimpleSean
6th gen SR5, 100 series
They put up a small battle, but in the end I whooped their butt...lol
Now I can't decide if I like the raw silver or do I install the red?
What was your process here? Doing a grill swap shortly and though red would be a nice contrast to my underground.
Use a heat gun until the outer letters start to curl and slowly pull off. Be careful not to pull the silver ones off that are underneath, they too are installed with double sided tape.
cbredesen
Orlando, FL
2026 TRD Off Road
A few Subtle modifications to the front end of my 4Runner TRD Pro. I removed the front recovery hooks and painted them red. Added a heritage badge to the front grille.
This looks good. Did you drill or use some adhesive? I have the same grille but blacked out and attaching with the little bar didn't go so well. I tried to fabricate a piece of metal to grab the back of the grill on the top and bottom of the open gap but even then I can't get a nut driver into there and tighten the nuts. Also the angles of the grill bits make it kind of unstable. Which one did you get?
gmarcucio
Glenn
Upstate New York
I used 3M two sided automotive molding tape
828findadventure
Tacoma & Tundra
Blaze off-road Garmin Power Switch bracket and wires. Great way to clean up the wire mess and control your lights wirelessly.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 IMG_5422
BonRunner
2026 TRD Sport Premium / WCP
Installed OEM hatch lights on the D-pillar. Quick & easy. Got them from recent sale at $185 shipped. Definitely a great improvement in visibility for the cargo area.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260426_153732
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260426_153807
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260426_160827
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260426_161052
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 20260426_154529
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 W0A3565-Edit
Desert_6Gen
Bronco
Added a 1" lift in the rear and put on some new 17" RRW wheels and 285/75/70 Toyo's. Just need to add Rough Country's larger fender flares to hide the poke.
KD2MYW
Phil
NYC
Bulletpoint grab bar mount.
Kind of encroaches on the passenger too much.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? 👨🏻‍🔧 🧰 🛠 IMG_1324
