CAMTuning
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
Do you have an idea on the maximum torque input for the AL80F trans?
Toyota doesn’t publish a hard “max torque input” number for the AL80F, and anyone quoting a specific figure is guessing.
In the real world, it’s less about a single torque number and more about heat, shift management, and how the torque is delivered. Smooth, controlled torque is what keeps them alive — not chasing a peak spec.
CuttingedgeSport
Wisconsin
2025 TRD Sport 4wd
I get it, just hoping that the trans is up to holding the torque if we can keep it cool enough and if the pressure can be increased enough to keep clutches alive.
I would love to find a decent core trans and torque converter to inspect and check out for improvements/mods.
Vincenzo
Southeast
A transmission with a “shift kit” will last longer than a transmission in stock form. That cushy shift that every car has is actually more damaging. The clutches are slipping, which causes heat and wear to achieve a comfortable gear change. I prefer to feel my shifts. I found these guys a long time ago when I had my Tundra. I never pulled the trigger though. https://www.importperformancetrans.com/
CAMTuning
CAMTuning
Cam
NM
yes that comfort is intentional slip. With tuning have full control of shift behavior for each gear, and each mode (normal, sport)
CAMTuning
CAMTuning
Cam
NM
Session 8: Pulling these concepts together, and what to monitor on your Cobb Accessport
If you’re running a tuned 4th Gen Tacoma / T24 truck, your dash should give you context, not anxiety. Here’s the clean setup I recommend:
1. KCLV (Knock Correction Learn Value)
This is your long-term knock learning value.
It shows how the ECU is adapting over time based on fuel quality and operating conditions.
You’re not chasing a perfect number — you’re watching for stability.
If it lives in a consistent range and behaves predictably, that’s healthy.
Sudden sustained changes are what matter.
2. Knock Correction Angle
This is real-time knock response.
You will see small corrections. That’s normal closed-loop strategy.
Important reminder that:
-3° = effectively 0.
Seeing -3 doesn’t mean you’re “losing 3 degrees.” It’s essentially baseline behavior.
What you’re watching for isn’t small blips — it’s repeated, large corrections under steady load.
Trends > single events.
3. Boost
Keep it simple. Just boost.
Know what your truck normally makes in:
  • 3rd gear
  • 4th gear
  • Typical temps
Toyota torque targeting means boost isn’t just a “max PSI” number — it changes based on load and conditions.
If you know what’s normal for your truck, you’ll instantly spot when something is off.
4. Charge Air Temp (Post-Intercooler)
Not generic intake temp — charge temp.
This is the temperature of the air the engine is actually ingesting after compression and intercooling.
This directly affects:
  • Ignition timing
  • Knock sensitivity
  • Torque consistency
If charge temps climb, the truck may feel softer — even if nothing is wrong mechanically.
5. Long Term Fuel Trim
This is one of the most underrated parameters.
Stable trims = sealed system, healthy airflow modeling.
Sudden swing = possible boost leak, vacuum issue, or MAF contamination.
It’s an early warning system.
What I don’t recommend:
  • Staring at AFR constantly
  • Chasing peak boost numbers
  • Turning the Accessport into a stress device
The goal isn’t constant monitoring.
It’s knowing what’s normal.
Once you understand your truck’s patterns, you’ll recognize changes early.
What are you running on your dash?
xp0nex
2025 4Runner ORP
Just curious, would a dyno tune be more dialed‑in than a remote tune, or is the difference pretty minimal? I’m mainly looking at a custom tune with revisions
CAMTuning
CAMTuning
Cam
NM
I've had the opportunity to road tune quite a few trucks, and follow up with dyno time (just did another this week) and the difference is negligible.
xp0nex
2025 4Runner ORP
Awesome! (y)
CAMTuning
CAMTuning
Cam
NM
Session 9: Bigger Tires & Why Your MPG Display Is Lying to You
We’ve already talked about how larger tires affect acceleration and effective torque at the wheels.
Today let’s talk about something less dramatic — but just as misunderstood:
Why your displayed fuel economy often drops after installing bigger tires… even when real efficiency hasn’t changed as much as you think.
The Simple Physics
Your speedometer and odometer are calibrated for a specific tire circumference.
When you increase tire size:
  • Each rotation of the tire covers more ground
  • The truck is traveling farther per revolution
  • But the ECU still thinks you’re on stock diameter
That means:
  • Your actual speed is higher than displayed
  • Your actual distance traveled is greater than recorded
And fuel economy is calculated using:
Distance Ă· Fuel Used
If distance is being under-reported…
your MPG display will also be under-reported.
Example (simplified numbers)
Let’s say:
  • Stock tire = 31.5"
  • New tire = 33.5"
That’s roughly a ~6% increase in circumference.
If your truck says:
  • 18.0 MPG displayed
Your real MPG could be closer to:
  • ~19.0 MPG actual
Not magic. Not a tune.
Just math.
What Actually Does Hurt MPG With Bigger Tires
Now — that doesn’t mean there’s no efficiency impact.
Larger tires also:
  • Increase rotating mass
  • Increase rolling resistance
  • Change effective gearing
  • Require more torque to accelerate
So yes, some MPG loss is real.
But very often the dash number makes it look worse than it actually is.
The Takeaway
If you’ve added larger tires and your MPG “fell off a cliff,” check:
  1. Tire diameter difference
  2. Speed correction percentage
  3. Hand-calculated fuel economy
You may find the truck isn’t as inefficient as the display suggests.
Until there is a good way to calibrate the speedometer to compensate for tire size or re-gearing, this will be something that owners will have to deal with.
CAMTuning
CAMTuning
Cam
NM
Session 10: Intake temperature and how it affects power output
As temperatures climb in the spring and summer, it’s normal to notice a small reduction in engine performance. This isn’t a tuning issue — it’s physics.
Warmer air is less dense than cold air, which means each intake stroke contains less oxygen. Since power production depends on how much oxygen the engine can burn with fuel, the ECU adjusts load targets and ignition timing to keep the engine operating safely.
On turbocharged engines, the turbocharger can help compensate by increasing boost, but only within its efficiency limits. Higher intake air temperatures also increase knock sensitivity, so the ECU may reduce ignition timing slightly, which further reduces power.
Another factor is heat soak. After repeated pulls, long climbs, or even sitting in traffic, the intercooler and intake system absorb heat from the engine bay and surrounding air. Once that happens, intake temperatures rise faster and take longer to recover, which can make the vehicle feel a little softer until everything cools back down.
This is also why the same truck that feels incredibly strong on a 40°F morning might feel a bit different on a 95°F afternoon, even though nothing has changed mechanically.
Higher-power vehicles tend to make this more noticeable simply because the absolute power change is larger. A small percentage loss on a mild engine may be hard to feel, but on a high-output setup it can be very obvious.
Upgraded intercoolers are often misunderstood here. They typically don’t add peak horsepower on a single pull, but they can help maintain consistent performance by reducing heat soak and keeping intake temperatures more stable during repeated pulls or hot weather driving.
