CAMTuning
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
Do you have an idea on the maximum torque input for the AL80F trans?
Toyota doesn’t publish a hard “max torque input” number for the AL80F, and anyone quoting a specific figure is guessing.
In the real world, it’s less about a single torque number and more about heat, shift management, and how the torque is delivered. Smooth, controlled torque is what keeps them alive — not chasing a peak spec.
CuttingedgeSport
Wisconsin
2025 TRD Sport 4wd
I get it, just hoping that the trans is up to holding the torque if we can keep it cool enough and if the pressure can be increased enough to keep clutches alive.
I would love to find a decent core trans and torque converter to inspect and check out for improvements/mods.
Vincenzo
Southeast
A transmission with a “shift kit” will last longer than a transmission in stock form. That cushy shift that every car has is actually more damaging. The clutches are slipping, which causes heat and wear to achieve a comfortable gear change. I prefer to feel my shifts. I found these guys a long time ago when I had my Tundra. I never pulled the trigger though. https://www.importperformancetrans.com/
CAMTuning
CAMTuning
Cam
NM
yes that comfort is intentional slip. With tuning have full control of shift behavior for each gear, and each mode (normal, sport)
CAMTuning
CAMTuning
Cam
NM
Session 8: Pulling these concepts together, and what to monitor on your Cobb Accessport
If you’re running a tuned 4th Gen Tacoma / T24 truck, your dash should give you context, not anxiety. Here’s the clean setup I recommend:
1. KCLV (Knock Correction Learn Value)
This is your long-term knock learning value.
It shows how the ECU is adapting over time based on fuel quality and operating conditions.
You’re not chasing a perfect number — you’re watching for stability.
If it lives in a consistent range and behaves predictably, that’s healthy.
Sudden sustained changes are what matter.
2. Knock Correction Angle
This is real-time knock response.
You will see small corrections. That’s normal closed-loop strategy.
Important reminder that:
-3° = effectively 0.
Seeing -3 doesn’t mean you’re “losing 3 degrees.” It’s essentially baseline behavior.
What you’re watching for isn’t small blips — it’s repeated, large corrections under steady load.
Trends > single events.
3. Boost
Keep it simple. Just boost.
Know what your truck normally makes in:
  • 3rd gear
  • 4th gear
  • Typical temps
Toyota torque targeting means boost isn’t just a “max PSI” number — it changes based on load and conditions.
If you know what’s normal for your truck, you’ll instantly spot when something is off.
4. Charge Air Temp (Post-Intercooler)
Not generic intake temp — charge temp.
This is the temperature of the air the engine is actually ingesting after compression and intercooling.
This directly affects:
  • Ignition timing
  • Knock sensitivity
  • Torque consistency
If charge temps climb, the truck may feel softer — even if nothing is wrong mechanically.
5. Long Term Fuel Trim
This is one of the most underrated parameters.
Stable trims = sealed system, healthy airflow modeling.
Sudden swing = possible boost leak, vacuum issue, or MAF contamination.
It’s an early warning system.
What I don’t recommend:
  • Staring at AFR constantly
  • Chasing peak boost numbers
  • Turning the Accessport into a stress device
The goal isn’t constant monitoring.
It’s knowing what’s normal.
Once you understand your truck’s patterns, you’ll recognize changes early.
What are you running on your dash?
xp0nex
2025 4Runner ORP
Just curious, would a dyno tune be more dialed‑in than a remote tune, or is the difference pretty minimal? I’m mainly looking at a custom tune with revisions
CAMTuning
CAMTuning
Cam
NM
I've had the opportunity to road tune quite a few trucks, and follow up with dyno time (just did another this week) and the difference is negligible.
xp0nex
2025 4Runner ORP
Awesome! (y)
CAMTuning
CAMTuning
Cam
NM
Session 9: Bigger Tires & Why Your MPG Display Is Lying to You
We’ve already talked about how larger tires affect acceleration and effective torque at the wheels.
Today let’s talk about something less dramatic — but just as misunderstood:
Why your displayed fuel economy often drops after installing bigger tires… even when real efficiency hasn’t changed as much as you think.
The Simple Physics
Your speedometer and odometer are calibrated for a specific tire circumference.
When you increase tire size:
  • Each rotation of the tire covers more ground
  • The truck is traveling farther per revolution
  • But the ECU still thinks you’re on stock diameter
That means:
  • Your actual speed is higher than displayed
  • Your actual distance traveled is greater than recorded
And fuel economy is calculated using:
Distance Ă· Fuel Used
If distance is being under-reported…
your MPG display will also be under-reported.
Example (simplified numbers)
Let’s say:
  • Stock tire = 31.5"
  • New tire = 33.5"
That’s roughly a ~6% increase in circumference.
If your truck says:
  • 18.0 MPG displayed
Your real MPG could be closer to:
  • ~19.0 MPG actual
Not magic. Not a tune.
Just math.
What Actually Does Hurt MPG With Bigger Tires
Now — that doesn’t mean there’s no efficiency impact.
Larger tires also:
  • Increase rotating mass
  • Increase rolling resistance
  • Change effective gearing
  • Require more torque to accelerate
So yes, some MPG loss is real.
But very often the dash number makes it look worse than it actually is.
The Takeaway
If you’ve added larger tires and your MPG “fell off a cliff,” check:
  1. Tire diameter difference
  2. Speed correction percentage
  3. Hand-calculated fuel economy
You may find the truck isn’t as inefficient as the display suggests.
Until there is a good way to calibrate the speedometer to compensate for tire size or re-gearing, this will be something that owners will have to deal with.
CAMTuning
CAMTuning
Cam
NM
Session 10: Intake temperature and how it affects power output
As temperatures climb in the spring and summer, it’s normal to notice a small reduction in engine performance. This isn’t a tuning issue — it’s physics.
Warmer air is less dense than cold air, which means each intake stroke contains less oxygen. Since power production depends on how much oxygen the engine can burn with fuel, the ECU adjusts load targets and ignition timing to keep the engine operating safely.
On turbocharged engines, the turbocharger can help compensate by increasing boost, but only within its efficiency limits. Higher intake air temperatures also increase knock sensitivity, so the ECU may reduce ignition timing slightly, which further reduces power.
Another factor is heat soak. After repeated pulls, long climbs, or even sitting in traffic, the intercooler and intake system absorb heat from the engine bay and surrounding air. Once that happens, intake temperatures rise faster and take longer to recover, which can make the vehicle feel a little softer until everything cools back down.
This is also why the same truck that feels incredibly strong on a 40°F morning might feel a bit different on a 95°F afternoon, even though nothing has changed mechanically.
Higher-power vehicles tend to make this more noticeable simply because the absolute power change is larger. A small percentage loss on a mild engine may be hard to feel, but on a high-output setup it can be very obvious.
Upgraded intercoolers are often misunderstood here. They typically don’t add peak horsepower on a single pull, but they can help maintain consistent performance by reducing heat soak and keeping intake temperatures more stable during repeated pulls or hot weather driving.
CAMTuning
CAMTuning
Cam
NM
Session 11: Why Two Tuned Trucks Can Feel Completely Different
One thing people often don’t realize is that two trucks with the same hardware and the same peak power can feel very different to drive.
A big part of that comes down to how the ECU interprets driver input and manages the transmission.
Modern Toyota ECUs use driver demand tables that translate pedal position into a torque request. The ECU then decides how to deliver that torque using throttle angle, boost, ignition timing, cam timing, and gear selection.
There isn’t just one “correct” way to shape that response.
Some drivers prefer a more responsive feel where the engine and transmission react quickly to pedal input. Others prefer a smoother progression where power builds more gradually and gear changes feel more relaxed.
I ran into a good example of this recently. A customer tried one of the sportier transmission calibrations and initially thought something was wrong because the truck felt too busy — like it couldn’t decide what gear it wanted to be in. Once we switched him to the OEM+ style calibration, which prioritizes smoother and more predictable shifts, the truck immediately felt right to him.
Nothing about the engine’s capability changed. The difference was simply how the powertrain responded to the driver.
That’s one of the advantages of working with a calibration designed for the platform — you can tailor the behavior of the truck so it matches how the owner actually wants it to drive.
Because the best tune isn’t just about peak numbers. It’s about how the truck feels every time you’re behind the wheel.
CAMTuning
CAMTuning
Cam
NM
Session 12: Airflow Numbers, Intakes, and Why Some Gains Don’t Stick
On a MAF (mass air flow) -based system, airflow is not directly measured mass in a perfect sense—it’s calculated based on what the sensor reports and how it’s calibrated. Change the housing, change how air passes over the sensor, and you can change the reported airflow without actually changing how much air the engine is ingesting.
A larger MAF housing or different flow path can cause the sensor to underreport (or overreport) airflow. The ECU thinks less air is entering than actually is, so it commands less fuel. That creates a lean condition—more air relative to fuel—which will often feel stronger right away.
That “feels faster” moment right after installing an intake is often not additional airflow. It can just the engine being under-fueled.
Over time, the ECU fixes it. The oxygen sensors see the lean condition and the ECU starts adding fuel through fuel trims to bring the mixture back to where it should be. Long-term fuel trims learn that correction and carry it forward, so even under load (open loop) the system trends back toward the commanded AFR.
Let's review some real data from customer vehicles.
Right after install:
LTFT near zero
Reported airflow may look lower, because the way the air is crossing the MAF has changed.
Actual AFR is leaner than commanded
Fuel Trims (green) 1-3%, but AF desired (yellow) is richer than actual (blue)
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1774450996243-vw
After some drive time:
Total fuel trims (mostly long term in this case) goes positive (adding fuel)
Commanded AFR and actual AFR line back up
“Extra power” goes away
Fuel trims (green) ~13%, but AF desired (yellow) and actual (blue) are well matched:
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1774450546543-5j
Properly calibrated fueling *after revision based on data logs- this is a real customer of mine, tuned remotely.
Fuel trims near 2% (green), AF desired (yellow) and actual (blue) well matched:
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1774450349168-7t
This is why airflow comparisons between intakes can show misleading data. If the MAF scaling isn’t correct, you’re not comparing airflow—you’re comparing sensor interpretation, and the engine running conditions are not a direct comparison.
Real gains from an intake come from reducing restriction pre turbo and improving how easily the turbo can move air. But if you see an immediate jump in performance without calibration changes, you need to wonder whether it’s actual airflow… or just a measurement shift.
Here's the key takeaway: airflow data only means something if the MAF is calibrated correctly.
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1774450533249-f9
CAMTuning
CAMTuning
Cam
NM
Session 13: E30 Ethanol Tuning Explained: Power Gains, Fueling Changes, and How to Mix It Correctly
Since I've been tuning more trucks on an ethanol blend lately, I figured I'd add an entry here to cover that topic.
A lot of people think running E30 is just adding ethanol to make more power but it’s not that simple.
Ethanol does a few key things that change how the engine can be tuned:
Higher knock resistance → allows more ignition timing
Charge cooling effect → helps reduce combustion temps and knock
More stable power → less timing pull under load
That’s where the gains come from—but only if the calibration is set up correctly.
The Part Most People Miss: Fueling
Ethanol requires more fuel volume than gasoline.
So when tuning for E30, we have to adjust:
Fueling targets (lambda)
Injector and fuel system behavior
If this isn’t done right, you’re not getting the full benefit—and potentially creating inconsistencies.
Why Ethanol Content Matters
Pump “E85” isn’t actually consistent. It’s usually anywhere from E51–E85 depending on season and location.
So if you’re trying to run E30 and just guessing your mix:
You might actually be at E20 → less knock resistance than expected, and richer AFR
Or E40+ → more fuel demand than intended (leaner AFR)
How to Do It Right
  • Use an ethanol content sensor (fuel-it, innovate, etc) if you run blends regularly, and use an E85 mix calculator app when filling up
  • Try to stay consistent with where you get fuel
Why E30 Works So Well
When everything is set up correctly, E30 gives you:
  • More usable power (not just peak)
  • Better consistency under load
  • A safer margin compared to pushing pump gas
E30 isn’t just about adding ethanol—it’s about controlling it and tuning for it properly.
Here's an example on my personal truck on 91 (stock) vs an E30 blend. This is with an intake and intercooler as the only 2 modifications:
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning SXTH e30
CAMTuning
CAMTuning
Cam
NM
Session 14: Stop Expecting Power from Cat-Back Exhausts
A cat-back exhaust is not a performance mod on a stock turbo truck- It’s a sound mod.
Cat-Back Reality Check
You can spend $1,000+ on a cat-back and gain… basically nothing.
  • No real horsepower gain
  • No meaningful torque change
  • No improvement in turbo efficiency
The truck doesn’t suddenly get faster. It just gets louder.
If it feels faster, that’s the noise talking.
Where Power Actually Comes From
The restriction isn’t at the back of the truck.
It’s right at the turbo.
That’s why the downpipe is the only exhaust part that consistently moves the needle:
  • Faster spool
  • More torque
  • Better airflow
  • Real, repeatable gains
This shows up in logs. It shows up on the dyno. Every time.
Green- stock truck
Blue- Intake, intercooler, stock downpipe, tune
Red- Intake, intercooler, FaF downpipe, tune
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning downpipe vs stock vs stockdownpipe
Common Mistake
People lump “exhaust” into one category and expect the same result.
It’s not the same:
  • Cat-back = noise
  • Downpipe = performance
Completely different impact.
And No…
A cat-back does not:
  • “Free up the engine” in any meaningful way
  • Suddenly add power because it’s “less restrictive”
  • Replace the need for actual airflow improvements
At stock turbo power levels, it’s not the bottleneck.
Bottom Line
If you bought a cat-back for sound, good—that’s what it’s for.
If you bought it expecting power, you bought the wrong part.
If you want actual gains:
  • Downpipe
  • Proper calibration
Everything else is just volume.
The highest quality, hand built in the USA downpipe is sold here:
FAF Race Downpipe
2025 2026 4runner 6th gen Tuning Facts - Understand Your 4Runner Like We Do at CAMTuning 1777309744027-ea
