bt75cj5
Bob
Washington
2025 Toyota 4runner, 2021 Jeep Gladiator
A huge shout out to the R&D crew at Warn Industries, they did a fantastic job on the new Semi-hidden winch mount for the new 25+ 4RUNNER!! It's a very clean look and the 12k Warn Winch is tucked away nicely! This kit is being released on Feb.2 to a shop near you!
Thanks WARN Industries !!!
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 28532-f21c6bd9c20aecd78ce91e056468fc65
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 20260116_163724
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 20260116_154809
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 28534-f05e0a3b200a76392d9a3db69df28146
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! 20260114_162812
2025 2026 4runner 6th gen WARN Semi-Hidden Winch kit for 2025+ 4Rrunner 6th gen! NOW AVAILABLE  !! Screenshot_20260202_161457_Chrom
Islandsnow
Joey
Modesto
BMW X5, BMW M3, Chevy Tahoe
Looks very good! I've got the Rago front bumper and it has the 20" light bar installed in it as well. There is a spot on the bottom of the Rago bumper to install a winch. My question how hard was it to access the clutch ontop of the winch? Did you have to squeeze your hands thru the small grill?
bt75cj5
bt75cj5
Bob
Washington
There is plenty of room thru the opening on each side of the license plate to access the winch. My stubby hands/fingers have no issues.. lol....
NWRes
NW WA
I have owned a few Warn winches and mounts. You stated this will be available Feb 2nd. Is this a Warn test bed and who performed the installation? What finish and materials? No information on their website yet. The best mount I have ever owned and still have is a Warn Transformer mount in stainless steel. Still no rust after 20 years.
bt75cj5
bt75cj5
Bob
Washington
Yes, this was Warn's "test" fitment and their R&D department did the install. It is all steal and is powder coated, very heavy duty! Warn definitely builds top notch products!!
NWRes
NW WA
I'm up in Bellingham. Did you take it down to Clackamas? Been looking for a mount. My days of doing my own installs are done. I want somebody who knows what they are doing for the install and a manufacturer I know and trust.
bt75cj5
bt75cj5
Bob
Washington
Yes, I dropped it off for the R&D department to do their magic.. :) i live south of Olympia, so it wasn't much of a drive.. Agreed, finding a good shop is difficult. I use Total Off Road in Tigard for anything I don't want to tackle...
bird
SF Bay Area
25 TRD ORP
This looks great! Are the front camera and radar still functional?
bt75cj5
bt75cj5
Bob
Washington
Yes they are, no issues what so ever...
Cranberry
Manitoba Canada
By chance are there any weights of the bumper confirmed yet?
12k zeon i assume is what they installed?
This is the first winch / bumper set up i think k iv seen that works with a 12K winch without significant modifications to the truck or winch.
I ordered my CBI super stock bumper almost 2 months ago and still have no word on expected delivery. I might need to order another brand like this Warn if they can guarantee realistic delivery times.
bt75cj5
bt75cj5
Bob
Washington
I don't have any confirmed weight yet, but will look into. Yes, it's a 12k Zeon synthetic winch. Fits nicely!!
jpa2002
Jon
Daleville, VA
2026 TRD Pro 4runner
I assume they had to run power leads from the battery in the rear hatch area? Can I get some pics of the underhood install?
Jon
bt75cj5
bt75cj5
Bob
Washington
Jon, yes they ran the cables to the main battery in the back. I'd be happy supply pictures, as requested when I return home.. Thanks..
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Can they not just run cables to the jump area in the engine bay? I heard you can install a switch hookup to that instead of having to run all the way back to battery.
KG7BTU
washington
N/A
I've read that the jump start posts are not rated for the kind of current that a winch would pull.
Edit: If we assume a 15 foot run between the winch and the battery (30 feet total), the wires should be 2/0 or 4/0 AWG to sustain 400A.
I'm not sure what the battery-to-frame connection looks like, but you may be able to run the ground through the frame instead of running the whole 15 feet of 2/0 AWG wire for the ground. A steel frame should be roughly equivalent to a wire twice the size of 4/0 AWG; but the limiting factor is the connections and risk of corrosion creating resistance (heat) at the joints.
