Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
PPF’d and Heat Shield on the Seibon Carbon Fiber Hood
Installed the under hood factory heat shield along with some adhesive backed aluminum heat shield and had the Seibon carbon fiber hood PPF wrapped in clear matte for protection from the elements but I love the way it looks too.
The PPF installer said this was a tough job because of all the different angles. In fact, I need to bring it back so he can finish the hood scoop.
Hope this helps someone who is considering a CF hood.
2025 2026 4runner 6th gen Matte Clear PPF and Heat Shield Install on a Seibon Carbon Fiber Hood IMG_4304
2025 2026 4runner 6th gen Matte Clear PPF and Heat Shield Install on a Seibon Carbon Fiber Hood IMG_4303
Ulysses
2025 4Runner Hybrid
You wouldn't happen to have a P/N on that scoop? I'm doing a hood swap but the scoop I was looking at buying, doesn't seem to have that honeycomb pattern in front. Your hood looks slick with the underground!
Minnesota4Runner
Woodbury, MN
2025 TRD Sport
I got ppf this week and the installer said the same thing. Pretty sure they will charge more going forward for Gen. 6's
Franco
Franco
Frank
San Clemente, CA
Thank you. Mine is all one piece (Seibon Carbon Fiber Hood - seiboncarbon.com ) and the hood scoop is functional (Hence the mesh) vs the Toyota OEM Sport Hood
Franco
Franco
Frank
San Clemente, CA
I PPFd my entire roof prior to installing the roof rack and just did the hood to protect the carbon fiber. Would like to do the entire vehicle at some point but it is really expensive.
I live in So Cal and had a shop in San Clemente do it (Detail King Express)
The_Dark_Knight_Forever
J.
Houston, TX
Looks awesome! Forgive my ignorance but what exactly are the advantages and disadvantages for switching to a carbon fiber hood?
Franco
Franco
Frank
San Clemente, CA
Thanks! Its 30% lighter, has a functioning hood scoop vs OEM which is decorative, TRD OR only comes with a smooth hood so you get the look and an actual functioning hood scoop. Definitely makes it look meaner too
BRunner
B
Stuff!
Wondering if you made any changes to the hood hinge mount springs losing so much weight with the Carbon hood?
Looks great!
OnePunchPan
Tristate area
Hey OP - Looks great!
Couple of questions:
1. I see hood pins as a requirement on their site, but don't see it on your pics. Are they installed or are they just not necessary?
2. Have you noticed any fluttering with the CF hood? Would love to switch over, but wasn't sure if it behaves in a way that would annoy me.
Def let me know your experience with it thus far!
Franco
Franco
Frank
San Clemente, CA
Looks great!
Thank you! I was a little reluctant to use the struts I had bought for my original hood, but ended up using those and they work perfectly fine. By that I mean, it feels pretty normal.
Franco
Franco
Frank
San Clemente, CA
Thank you! Good questions
I did not use any hood pins and have not seen anyone who has. The hood closes just like a factory hood with a great fit and sound when it shuts
I just took a road trip of over 1000 miles driving up to 85mph with wind and it did great. I do notice that the center of the hood does seem to move up and down a bit on some bumps.
It is much higher than the smooth hood so I moved my seat up higher to see over it better (Im 5' 11")
Those are the "downsides"
Hope that helps
OnePunchPan
Tristate area
Hope that helps
This helps a ton thank you! Esp with the height as I'm also in that range and was wondering how it'd impact overall visibility/driver feel. Nothing irritates me more than things I notice on long road trips haha
OOC, how much does the stock smooth hood weigh? I notice a magnet won’t stick to mine so I assume it’s Al. It appears to be the only exterior panel that is.
Franco
Franco
Frank
San Clemente, CA
Not sure...
