perryj101
Joe
St. Peters, MO
2013 Toyota Venza XLE
Wheels are +20 offset
PT946-35240-2F wheels
You can buy the wheels online for $222 each.
https://parts.elmhursttoyota.com/oe...trd-pro-flat-black-18-quot-wheel-pt946352402f
Did you have to use hub-centric rings when installing these on your TRD Sport Premium? My understanding is that the 4Runner hub bore is larger than the Tacoma hub bore. I am waiting for my TRD Sport Premium to come in and want to buy these wheels to replace stock wheels but want to make absolutely sure they will fit with no issues before buying.
JR1
JR1
Joe
Missouri
Those are 2025 Pro wheels. They are a perfect fit for a 2025 4Runner. The hub bore, bolt pattern are all for the 2025 model. You will NOT need any rings. I did purchase new valve stems from the dealer. If you click on the link, the specs are listed.
perryj101
Joe
St. Peters, MO
Thanks! I guess I was thrown off by the description when going to the link because it says 2024+ Tacoma wheels.
Supersonic Red 4runner
Ken
Queens, NY
2025 Red 4runner
I’m 100% positively sure the 2024+ Tacoma wheels are same lug pattern & hub bore size with 2025 4Runner with Zero add-on or modifications needed , because I’m currently using a set of 2025 Tacoma TRD Pro wheels. They are the same wheels
JR1
JR1
Joe
Missouri
The new Tacoma gen started in 2024, a year earlier than us. Same overall platform so the commonality is there.
I’m almost positive that these wheels are for the 2025 Pro 4Runner and the Tacoma Pro. I didn’t purchase them because of that. I really like the way they look and the satin ish finish. My 24 Terra Pro wheels were more of a matte black. I much prefer the satin look.
perryj101
Joe
St. Peters, MO
Do you know the part number for the valve stems? I just see a description in the link with no part number listed. I guess I could transfer the valve stems from stock wheels to new wheels as an option.
Joe Dirt
These are 2025 TRD Pro 18” wheels with Mickey Thompson Baja Boss AT tires.
The tires are 265/65/18 which is almost the same size as the stock Geolanders at 265/55/20.
No lift or leveling kit.
Before (stock TRD Sport wheels)
20x8" inch machine finished alloy wheels
31.5" (265/55R20) Yokohama Geolandar A/T G015 tires
That's pretty nice to see a 265 that means the tire is a little narrower. Hard to find that size in any of the other manufacturers. So you're right at the factory 33 inch diameter. How are the MT's? pretty solid I'll bet? Thanks in advance.
