2025 Big Red
Ron
4 Runner 2025
Aww man! I can't wait to try this after work. Mine hasn't been working (except the steering wheel position). I was thinking I was going to have to take it into the dealership. It's been soo annoying trying to get the seat back to just where I like it after the Wifey drives it. She leaves that seat all the way forward and jacked up to Jesus!:ROFLMAO:
I did I go to dealership. All they did was hold Set and #1 at the same time and worked. I was pressing Set, let go, and then pressing#1. Worked after that.
Cityzen10
Ryan
Gresham OR
Easy fix, I bought the wife the car she wanted. Now I'm not allowed in it and she's not allowed in mine :)
I'll have mine paid off in a few weeks, I like your style, I may just do the same. After letting her drive it a few times, she's getting a little too comfortable in it for my liking. ?
beanmachine
Brandon
Saratoga Springs NY
ORP Premium
Thanks for this tip!
Totally worked for mine also.
Dealer apparently didn’t do PDI on tire pressures either… I was rolling around on 45psi. I hadn’t figured out how to check the on board monitor when we left the dealership after a long wait. Didn’t check it until a few days ago and 430 miles on Odo.
Rides so much better at 34psi!
How did you get the correct reading for tire pressure?
RogueWarrior65
Blair
Okay, so, I needed to do the calibration procedure because the seat would beep as I was moving it. That's fine BUT, the memory button still doesn't do squat. What's worse is that if the seat got moved for some reason e.g. I leaned on one of the controls as I was trying to reach for something, that position becomes the new startup position. WTAF? Is there any way to clear everything out and start over? Is the key fob messing with me? I never tried to program that.
you sure the set button isnt stuck in the down position?
you have to press the set and 1 or 2 button to set a pre-set
if you can press the 1 or 2 button without the set button, to set a pre-set then something is wrong.
RogueWarrior65
Blair
I'm a bit mystified by the calibration procedure. It uses forward/back and recline, both of which make perfect sense. But then it uses "up/down". Which one? The up/down control does two things. The YouTube video mentioned above uses the front part of the seat but not the whole seat. And why isn't the lumbar control part of this?
Marc
Maryland
2025 TRD ORP
I had this issue and foxed it with the above procedure BUUUTTTTT......the sideview mirrors do not have any memory.
ColoradoRoz
Roz
Parker, CO
2025 trd orp 4runner
I just got my TRD ORP delivered today and the seat memory wasn’t working. The seat would beep whenever I moved it in any direction. Here’s the fix I found on Toyota Nation. Just sharing here in case anyone else has the same issue.
“I have distilled the instructions below … basically, you have to initialize the seat memory feature before you can program it. I guess some dealers do it before handing the car over to the customer, but some dealers evidently do not - go figure!
Here’s the Seat Memory Initialization procedure I found to work:
This procedure is not in the manual, as far as I can see.
To initialize the Driver Seat memory feature, perform the following steps, (starting from outside the vehicle with the driver’s door open):
1. Move the driver’s seat forward to its limit.*
2. Move the driver’s seat to its full height.*
3. Recline the driver’s seat all the way back.*
4. Hold the SET button and press 1.*
5. Move the seat far enough back so you can get back in and sit in it.
6. Adjust the driver’s seat to the desired seat position.
7. Hold the SET button and press 1.
8. Program the key fob, if desired, by following the instructions in the manual.
[*NOTE: Steps 1 thru 4 have to be performed from outside the car with the door open, because the extreme forward and high seat position precludes sitting in it!]”
-Thanks to Pique F at toyotanation.com
Thank you so much for this! My wife and I both use the car often enough that this was starting to drive me crazy.
sometimes you only need to slide the seat forward and backwards and up down to the limits to initialize the seats.
#8 you need a profile and slide the button to turn on the fob to that profile in the head unit. also have your seat set to the position of the person to set it to that fob/profile when you set the fob to profile.
i usually set memory #1 to the wife and #2 to my self under each profile and each vehicle (23 tundra and 25 4R)
that way if i take her fob it will set the seat to her profile but i can have my seat setup tied to #2 memory when i take her fob but revert to the default seat setting when she drives again with her fob.
and always set the primary profile to the same person (on the tundra and 4R i am the primary driver)
but the seats and steering and mirror profiles are tied to the fob and profile that fob is tied to.
Cranberry
Dan
Manitoba Canada
I can confirm this worked for me :). Tha k you for posting this.
