n2mp60
Denver, Colorado
2026 4Runner
Just installed the ScanGauge 3 in my 26 ORP. It had been in my 23 ORP, mainly to monitor temps when towing a 16' Airstream through the mountains in Colorado.
Direct connect from the OBDII connector to the ScanGauge 3 display. Super fast update rate.
https://www.scangauge.com/product/scangauge-3/
2025 2026 4runner 6th gen ScanGauge 3 OBDII Vehicle Monitor - installed PXL_20260305_180605696.RAW-01.COVER
2025 2026 4runner 6th gen ScanGauge 3 OBDII Vehicle Monitor - installed PXL_20260305_180613155.RAW-01.COVER
2025 2026 4runner 6th gen ScanGauge 3 OBDII Vehicle Monitor - installed PXL_20260305_180619002.RAW-01.COVER
2025 2026 4runner 6th gen ScanGauge 3 OBDII Vehicle Monitor - installed PXL_20260223_162443048.RAW-01.COVER
Not made in China
Bicycle
Nice job. I run an older scanguage in my F350 (20 years old). Still works like a champ. Not a fancy color screen though :)
n2mp60
n2mp60
Denver, Colorado
2026 4Runner
I went with Bulletpoint Mounting Solutions as there isn't a lot of room for a mounting arm behind the Scangauge monitor. The Bulletpoint ball is 20mm, which is 5mm smaller than the standard Ram Mount ball.
https://www.bulletpointmountingsolu...h-integrated-20mm-ball?variant=40658713346163
https://www.bulletpointmountingsolu...h-integrated-20mm-ball?variant=40658713313395
https://www.bulletpointmountingsolu...evlar-hybrid-mount-arm?variant=32025333006451
I designed and 3D printed a custom cradle for the monitor, as there really wasn't anyway to directly attach the ball to the monitor. The STL file available on request. Double sided foam tape holds the monitor to the cradle.
LostInAZ
Carlos
2026 Toyota 4Runner ORP
Would a 3M tape mounted MagSafe magnet fit on the back of the display? There's plenty of 3rd party MagSafe mounts that are easily converted to almost any surface method. The TRD power button MagSafe is a prime example.
n2mp60
n2mp60
Denver, Colorado
2026 4Runner
There's not much weight to the Scangauge monitor, so I would imaging that would work as well.
As an engineer, I'm always leaning toward a more complex solution. :)
Vincenzo
Southeast
Heat is an issue. Like was already mentioned, it’s not that heavy. The 3m heavy duty was not holding up due to heat. I ended up using a “dual lock“ style Velcro that is holding up to the heat. It also makes it easily removable.
Mman611
Michael
Ansonia, CT
2006 Subaru STi, 2019 Lexus IS300 RWD, 1995 BMW M3 (track toy), 2021 KTM Duke 39
@n2mp60 thank you for sharing this setup. I’ve been considering the ScanGauge3 to watch temperatures while towing too
would you mind sharing a picture of your center console setup? I spy some bullet proof mounting
Mman611
Michael
Ansonia, CT
@n2mp60 was more thinking about the set up you have near the screen in the middle of the vehicle. I’m currently using the bullet proof mounting “Tacoma” handle mount but thinking about adding another. Looking for ideas
josiahg52
Josiah
Maine, United States
I'll be getting one for my Trailhunter. Used the SC2 in my M5, Tahoe, X5, and Ram 2500, then fairly recently bought the SC3 for the X5 and 2500. I've always used a modified Garmin 1450 windshield mount and 3M Dual Lock recloseable fastener tape in the upper left corner of the windshield but might go with a Bulletpoint Mounting Solutions mount this time. Could mount my phone, the SC3 and a Garmin GPS (backup to Android Auto).
