PSC System is Laughable at Times
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
My Toyota unexpectedly slammed on the brakes today, freaking me out, because it mistook the guy in front of me on a motorcycle as a pedestrian entering the roadway. I was doing 45 mph at the time.
BruceB
Bruce
Olympia, Washington
Chevy Silverado Z71, 4Runner TRD ORP Hybrid
I like the feature in theory, but ended up disabling it because it was braking in a lot of situations where I felt it was not necessary for the vehicle to brake.
For example, the vehicle in front is turning and I know when I get to where the vehicle is, it will have already turned off, but it is still close enough to the intersection for the 4Runner to brake.
mcd_ovrlnd
mcd_ovrlnd
SE PA
Do you just manually disengage it every time or did you turn off through something like a Calista?
BruceB
Bruce
Olympia, Washington
I don't own something like Calista and I don't have to manually disengage it every time. I turned it off in the settings in the digital gauge cluster.
I did it after watching the video below (PCS system is at about the 6:40 mark)
mcd_ovrlnd
mcd_ovrlnd
SE PA
Yeah, but that only disengages it during that specific ride. Turn the car off, and it’s back on. I thought you were referencing a way to permanently turn it off.
Kurvet [SCAMMER]
Banned
Banned
Banned
Your Toyota’s Pre-Collision System (PCS) likely experienced "phantom braking." Newer TSS systems can occasionally misread motorcyclists or road obstacles as pedestrians, abruptly triggering maximum automatic emergency braking.
BruceB
Bruce
Olympia, Washington
I stand corrected, but ever since I did it, my vehicle has not automatically applied the brakes, so maybe there is another setting I changed that I forgot I changed.
BruceB
Bruce
Olympia, Washington
Looks like I was confusing PCS with PDA. I turned off PDA. Sorry about that :)
I think I turned that off for a while (whichever it is called ;-)) but turned it back on again after I had the vehicle for quite a while. I think I now have all the safety features related to driving/collision on now. It does brake some (not hard braking) at times when maybe not quite necessary, but also reasonable. I have yet to have any case where I felt it did something stupid. The only time close to that is parking and getting to close to a bush :).
Mattb124
San Jose, CA
2025 4Runner TRD Off-Road
You are able to reduce the sensitivity to the lowest level which makes it more tolerable, but that is still my biggest disappointment with the vehicle.
And to make matters worse, if mine dings me 2x for following to closely in quick succession, it requires me to hit the brake pedal before it will allow me to accelerate. I can only image what a driver behind me might think as it could be interpreted as a malicious brake check.
Oh right, I recall now I did tone it down to the minimum level. I found that to be quite tolerable. I figure as long as it is a minor annoyance at most (I am not sure if I would even elevate it to the level of annoyance) I appreciate any help the system can give me in safety. No, of course it does not take the place of proper safe driving, but everyone gets distracted or simply may not react quickly enough--or not see something like a vehicle in a blind spot. I think I am a pretty decent driver but still the systems in this car have helped catch things a bit better or quicker.
JabbaJones
Jabba
Midwest
Toyota 4runner Trailhunter
My annoyingly will beep at turns when it thinks that vehicle turning ahead of me is stopped or when I try to accelerate from a stop and it thinks that I will collide with the vehicle ahead it will cut the throttle off. Genius. I think those systems create more danger than help...
Tarekith
Upper Left US
4Runner ORP & ‘22 Tacoma OR
Mine frequently sees dead people when I’m backing out of parking spaces at the grocery store.
ThatSickRIp
TSR
VA
2026 4Runner SR5
Not the 4R, but we took the Old Ladys LC on a trip last summer with a hitch rack on the back so the dogs could have the cargo area. Backing out of the driveway, the LC slammed the brakes and jolted the hell out of all of us. She yells at me thinking I did it on purpose 😂 Found out how to turn it off real fast after that
