Help w. Carplay
Lamuncha
Don
new england
2025 4 runner
As Brumey suggested using the cable eliminates the problem. I have tried without the cable for 4 months without real repeatable success. Bit of pITA but.......
Same with the adaptive cruise control. Truck passes on the right and my truck tries to stop, just perfect on the highway.
The real problem is this fault is inconsistent. Feature now off to the trash.
SteveS
Steve
Puyallup, WA
FOr folk reading this, its important understand that Apple CarPlay uses Bluetooth AND Wi-Fi. If your phone is using another Wi-Fi connection it will not work with Bluetooth alone.
6thGen1419
Peter
New Mexico
Sort of. When I get in the car on my driveway, my phone is still connected to my home WIFi and the phone connects to CarPlay just fine. You're right that it uses WiFi and Bluetooth, but it seems to handle it fine and connect to CarPlay when my phone is connected to my home wifi when I start up the 4Runner.
For example, when I have WiFi off on my phone, my 4Runner complains when connecting to CarPlay.
L-2
Nevada & California
2017 Tacoma Off-Road, 2014 Acura MDX, 2025 4Runner TrailHunter
I admit this internet mobile connectivity stuff is a bit beyond my comprehension.
For my iPhone, presently an iPhone 13, need to have both Bluetooth and wifi turned on, to stream info into my 6G4Runner, whether I connect my USB-C cable from the head unit to my phone or not?
I believe at least a partial answer must be yes or I wouldn't be able to even receive my usual Pandora music while I drive or use Apple or Google Maps apps to navigate while driving and glancing at the headunit or getting spoken directions.
Why does wifi need to turned on in my iPhone if I can't get a wifi connection while driving on the freeway or if I'm hardwired into the headunit? Maybe I am getting wifi signals while I'm driving besides my unlimited cellular 5G/5G+ with AT&T, but as I said, it may be beyond my understanding.
I do usually leave Bluetooth and wifi on in my phone all the time, but occasionally may have turned one or the other off for some weird or specific reasons and forgotten to turn one or the other back on.
It has to do with bandwidth limitations for Bluetooth. Your phone creates a wifi connection between itself and your car for heavier data usage needs, maps, streaming music. It can handle phone calls and text messages with only Bluetooth, but for everything to work you need to have wifi on your phone on. The same is true for Android Auto.
6thGen1419
Peter
New Mexico
I learned from AI that if you want to do CarPlay wired, you need to use the USB connector on the screen, not the USB chargers under to center console, which are apparently charging-only.
L-2
Nevada & California
OK to both responses, to me above. Yes, I do use the USB-C directly to the headunit's screen.
If wired isn't working for you it could be your cable. Are you using the Apple lightning to USB-C cable or another brand? Oddly, on my previous car when I tried to use the Samsung USB-C cable, it never worked right. I ordered a higher rated Anker one and I never had issues again.
L-2
Nevada & California
I never mentioned having any problems especially with my cable. Maybe this is why I get confused reading this forum. When I say/type something, I can be misunderstood as well as when I read something somebody else types.
No worries. Confusion is easy over a medium such as this.
"For my iPhone, presently an iPhone 13, need to have both Bluetooth and wifi turned on, to stream info into my 6G4Runner, whether I connect my USB-C cable from the head unit to my phone or not?"
I took this as having issues with wired because if your wired is working you shouldn't need wifi on. Just Bluetooth.
For Android, I run cabled now because for some odd reason I get cut outs on wireless Android Auto when I pass certain radio towers and my music or audio book skips like a CD player. So I just run the cable to the head unit and call it a day.
L-2
Nevada & California
I can't even type correctly anymore.
My prior question had bad grammar:
I MEANT TO TYPE: For my iPhone, presently an iPhone 13, do I need to have both Bluetooth and wifi turned on, to stream info into my 6G4Runner, whether I connect my USB-C cable from the head unit to my phone or do I not need Bluetooth or wifi turned on?"
Thanks everyone for answering. I believe the answer is Bluetooth and wifi should both be turned on in my iPhone when using Carplay, whether my iPhone being wired or not to the 4Runner's headunit. I'll try to stop here at this point as I start to confuse myself with questions, although I may return in the future.
I'm editing/amending my response, somewhat. If I'm using a cable between headunit and phone, as I normally do, I don't need to have either Bluetooth or wifi turned on while I drive. However, there's no usual reasons for me to turn them off anyway, at least in the car. Cellular does need to be on for streaming Pandora or Google Maps, as examples of what I might use. More questions keep popping into my head as I type, but I'll stop for now.
axxman
Axel
Columbia MD
2026 4Runner Off Road Premium (fall 2026)
"For my iPhone, presently an iPhone 13, do I need to have both Bluetooth and wifi turned on, to stream info into my 6G4Runner, whether I connect my USB-C cable from the head unit to my phone or do I not need Bluetooth or wifi turned on?"
To stream you need cellular turned on. if you are "connected via cable" no bt and Wifi do not need to be turned on. just to be thorough, if you are "connected via BT and WIFI" you need them both turned on to have Carplay.
L-2
Nevada & California
Post 27, I admit I can't remember all configurations I've tried, just for fun, but I should be able to use Carplay when a cable is connected between my iPhone and the headunit; with both Bluetooth and wifi off on the iPhone.
Now as I've previously configured my iPhone to automatically connect wirelessly with the headunit, this may introduce some further configuration between headunit and iPhone. When I get around to it, I'll turn off BT (bluetooth) and wifi on my phone; starting up the 6G 4runner either with the cable plugged in prior to starting or not, but the iPhone, essentially acting as an old iPod, should work.
Perhaps somebody else might check this method and respond before I get around to do it.
10/24/26: I finally remembered to try out my iPhone 13 with just the cable connected and BT and Wifi OFF. I couldn't make the anything from the iPhone work, although the headunit said iPhone was connected. I thought there might be a way just to play the music library but I saw no way to access it with the headunit. I no longer have a working iPod or any MP3 players so I don't know how these might work either with my '25 Trailhunter (just me wondering; nobody asked that question). With BT, Wifi both on, and a cable connected to the iPhone and headunit, I know everything works as it should. I understand using a cable is optional but I use it anyway.
josiahg52
Josiah
Maine, United States
I'm an Android user, but I would assume so. The question is what does your phone and the 4Runner prefer and could there be a conflict between the two methods? Wired was used for older phones, older infotainment systems and older versions of Carplay.
6thGen1419
Peter
New Mexico
In the 4Runner, there are actually two wireless technologies involved:
* Bluetooth is used initially to discover/pair your iPhone with the vehicle and establish the connection.
* Wi-Fi then carries the high-bandwidth CarPlay connection—audio, maps, Siri, apps, etc.
So the important distinction is:
Bluetooth = pairing/handshake
Wi-Fi = the actual wireless CarPlay data connection
