Help w. Carplay
as stated above, BT is use to do initial connection, then its handed off to a wifi connection. if you want to watch your music die, kill the wifi connection
it will look something like this
smartphone connect xxxxxx
i have that particular connection set to auto re-connect so if something happens it will retry several times before timing out.
2025 2026 4runner 6th gen Help w. Carplay 2026 4Runner BT and Wifi Connections
axxman
Axel
Columbia MD
2026 4Runner Off Road Premium (fall 2026)
I will try to take some photos and post them of what you should see. if I was within a reasonable distance I would show you myself but Nevada is a little far for me.
I apologize if this has been asked before, 1. I assume that since you have a trailhunter then we are talking about the JBL stereo system. it Shouldn't matter, they are mostly the same.
3. and again sorry if asked before but you do not have the ATT hotspot turned on (the car's hot spot)
The Garmin unit (i have the drive smart with the 6 inch screen) potentially will mess things up if it has wifi on, the phone may try to connect to it, or vise versa.
