ropdykex11
Rich
Portland, OR
2025 4Runner TRD Off-Road
I don't know for sure, but it is likely to be a more durable and higher-performance rubber compound. Plus it will likely be the same price. Worth the wait for me!
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
I have been running the gen3 prototypes and they're excellent. They changed how the bumpstop compresses / deflects under load.
ropdykex11
Rich
Portland, OR
@alldogsoffroad I have a question for you
I purchased the Bilstein 6112 front and 6100 rear kit for my rig. Obviously I will be upgrading the rear bumpstops to Perryparts V3 when they're out.
As far as the front goes however, the 6112 has an integrated bumpstop on the coilover. Do you still recommend adding the bumpstop tower from the LC250 to the front? In addition to the integrated bumpstop?
Pic from the 6112 spec sheet:
2025 2026 4runner 6th gen Front & Rear Bumpstops Upgrade (brackets from LC250 / GX550 are direct bolt-on) 1779588180467-l
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
If you're offroading aggressively I would recommend it. If you're mallcrawling then it isn't necessary.
josiahg52
Josiah
Maine, United States
Any experience on what works on the Trailhunter trim woth the OME suspension?
josiahg52
Josiah
Perry recommended their OE height Mk3 stops for the Trailhunter.
- Cannot find a torque spec for the front tower bolts
- The bump stop bases torqued as specified by Perry
- Perry rear mounting plate bolts - only unofficial number ive seen is 25 ft-lb
