Suspension Stock Travel Front and Rear
Rusty Rattler
Rustyrattler
Bullhead City Az
2025 Toyota 4runner ORP
Does anyone have specs on the travel of suspension?
A) Without pre load?
B) With weight of vehicle?
This would help all of us to determine which tires and offset combinations will work best
Thanks……
nubbins_
Thanks……
Until someone goes and does the measuring, the next closest might be tinkerer's measurements for the LC250? I can't seem to find the exact video for the life of me, but he definitely had the First Edition on the ramps at one point to test articulation - shouldn't be terribly different from a nonhybrid TRD Off Road
LC's general wheel/tire fitment limitations are also pretty similar to the 4R which seems to support that. Although iirc 4R might have a slight edge?
I should add, I said nonhybrid because the gas 4R and hybrid LC would share the 8.2" rear axle, whereas hybrid 4R would be the 9.5". But curb weight wise the hybrid would be closer (and thus one would think potentially spring rates would be closer), so idk which way to lean
