Fog Light Recommendations
voodooblues
Mississippi
2026 Toyota 4Runner TRD Pro
I was planning getting a set of Alpha Rex fog lights but after looking at their website they are not compatible with my TRD Pro. It says they will not work if the stock lights are Rigid. With that said, got any recommendations for a good set of amber fog lights?
voodooblues
voodooblues
Mississippi
You already have it. 😉
Press your fog light button in the cab again. They can do amber and white.
I thought that was only an option on the Trail Hunter?!?!
ScoMay
Tennessee
2022 Ram 1500 Rebel
I’m not against it! Thanks!
I ran into the same problem. I wished the Pro also had the switchable fog lights like the Trailhunter. Did not want to replace the lights themselves as it looked too complicated.
So I went with these from CaliRaised. They are for the Tundra & Sequoia so they need to be trimmed, but it was easy.
Note that they look YELLOW when they are turned on (not that attractive as you can see in their product photo). But they are a perfect AMBER color match to your Pro’s DRLs when they are turned OFF and that’s all I wanted.
That Lamin-X brand had some negative reviews so this gives you another option.
It is merely a cosmetic improvement, nothing more. And a cheap ($13) fix.
https://caliraisedled.com/products/2022-tundra-fog-light-overlays?variant=43770512343082
Virtual-Chris
Vancouver, BC
2027 4Runner
If you really like the Alpharex, I would investigate why the Alpharex can’t replace the Rigid. Are they saying that because of the wiring in the Trailhunter (not realizing the Pro doesn’t have the dual mode)? if this is the case, maybe it’s not that they are incompatible with Rigid equipped trucks, but that theyre not compatible with Trailrunners? Or is it a fitment/mounting issue In which case, maybe you can fab some mounting solution? I would look into it a bit further before giving up.
voodooblues
voodooblues
Mississippi
That’s a good idea, I’ll contact Alpha Rex and see what they say.
