Factory transmission fill check
Joe Dirt
Has anyone checked the factory fill on their transmission?
I will be doing mine tomorrow after I make my coffee run. It should be good and warm when I get back, will check the temperature; then check the fill level. Will try to report back with findings if I remember.
mcnuggs
4Runner TRD PRO
What is the best way to check?
typical toyota transmission check requires a cold engine, the bring it up to a specific check temp, then pull the either the drain or fill cap and see if its level with the hole.
just have to find the correct procedures for you model (4R, taco, tree, tundra, etc)
Joe Dirt
Joe Dirt
I would like to hear people's thoughts on this newer model. Mine does not have a drain with a separate fill level tube drain.
My 5th gen had two ( drain and fill tube).
This is not a hard procedure it just requires a hot trans and being underneath it while running!
I'm not really worried but just like with my engine oil I like to make sure that it is at the right level as well as all my other fluids. Going sight unseen is not my normal trust Factor. Just my two cents
