Crossbar choices for factory rails??
mdmountainman
Maryland
2025 4runner iforce max limited
sounds like good plan! I just picked up some cargo molle & pet barrier from Victory, all their stuff seems super solid. I ended up going 3/4 rack from Westcott Designs as want to leave it on.
I almost switched and got the victory 3/4 length. If my use case changes and I end up needing them a lot, I can always go to something like that later. 👍
Tom4run
Tom
Is any one heard or try Rhino SportZ cross bars ? all I'm trying to install my RTT. (Skycap mini 3.0) or spend little more and get a 3/4 ARB rack
mdmountainman
Maryland
Well Installed the victory 4x4 crossbars and I have to say that I am a bit disappointed. They come off with tools but not as easily as I had hoped. The hex head screws seem to be cheap as I stripped one of them tightening it. Tgere was also a couple corners scuffed on one of the brackets. I just dabbed with some paint and nobody will ever notice it but it was there.
I was also hoping there was an outside chance the noise wouldn’t bother me and I could just leave them on but they are LOUD. Like really LOUD.
2025 2026 4runner 6th gen Crossbar choices for factory rails?? IMG_7655
SF6G
San Francisco, CA
26 4R TRD Pro - Underground
We're running Yakima Timberline towers with HD bars from a previous vehicle. They're a beefier bar than the stock crossbars, so they do generate a bit more wind noise. Wanted to stick with the HD bars as they are flat and do not have a slight curvature to them. We primarily carry bikes but want to have a heavy duty bar for a RTT down the road.
2025 2026 4runner 6th gen Crossbar choices for factory rails?? IMG_7994
2025 2026 4runner 6th gen Crossbar choices for factory rails?? IMG_7995
Coldwiz
Frank
Saukville Wisconsin
I am wondering if the Rago bars are loud. The seem like they'd be ok, especially if a wind fairing could be designed for the factory rack.
mdmountainman
Maryland
As mentioned above, they are virtually unusable unless absolutely necessary. Extremely noisy.
AZ_RS
AZ
26 ORP
Wanted to see if you've had any issues with this setup yet? Any issues with the low weight load limit on the bars?
RandomSquirrel
Ashburn, VA
'26 ORP Hybrid, '95 BMW 318ti, '93 Ford Mustang, '13 Triumph Rocket III Roadster
Bringing this back to the top.
I am looking at either going 3/4 rack or just adding crossbars. While browsing crossbars, I saw Victory has a new option: https://www.victory4x4.com/product/V4RRKCS-6G.html Does anyone have any experience with these bars? I saw the reviews of their other crossbars, but these appear to be more of a "platform" and include a wind deflector. With the current sale, their 3/4 (short) rack is only $100 more, so looking to compare/contrast if anyone has experience with either. Thanks in advance!
Coldwiz
Frank
Saukville Wisconsin
I have seen one or two people on the FB 6th Generation Toyota 4Runner group with the new Victory option. Feedback sounded good. Not sure how to mount an awning, if you care. And looks like the fin is higher than the rails which might cause a problem depending on what you carry on your rack.
ToYoDaMan
Allan
Bay Area
Is this the one you are referring to
4Runner Platform Roof Rack | 6th Gen (25+)
I think it's a great option if you wanted to keep the oem roof rails.
Coldwiz
Frank
Saukville Wisconsin
RandomSquirrel
Ashburn, VA
With only ~$100 difference between the two, I sort of like they 3/4 (short) rack they offer compared to the 3 crossbars for the factory rails. Both appear to sit at the same height, but the 3/4 rack offers more load capacity. I won't be doing a ton of load, but mostly use for carry snowboards and kayaks.
